U
ultrajosh
I bought a 16-channel "home-built" mixer off eBay for peanuts and I'm amazed to find that it is really well built with what appear to be quality components. Some wacky Canadian locked in a cabin for a long winter with a soldering iron, I guess. I'm hoping to use this mixer for recording and mixing with my Tascam MSR-16S.
The frame is made of wood and is well-shielded inside. There are Beyer transformers on each channel strip, and the boards appear to be from a small batch - some are un-marked and others are marked EK 75 and EK 76. (Could this have been a mail-order kit?). The back panel appears to be from another mixer and has all XLR inputs/outputs.
The strip faces are grey/blue and appear to be professionaly silk-screened in white; the knob marks in the master section all go up to 11! Is that unusual? Have I found Spinal Tap's actual mixer?
Each channel strip has a buss-assign toggle for each of the 8 busses, 4 channels of switchable EQ, a built-in compressor/limiter, an Echo/Return section, and then two mystery toggles and a mystery red button.
There's an 8 VU meter bridge that seems to be hooked to the busses, but there are also several knobs and buttons on the meter bridge that I haven't figured out, yet. There is a knob beneath each VU meter that seems to also control the volume of the channel.
There are separate power supplies for the board and for phantom power.
All 8 buss outputs DO put out signal. And the phantom power also seems to work. But the master section isn't working at all, no matter what buttons I push. The Stereo Outs in the back don't work, and only one of the 4 Monitor channels works.
I pulled the 3 cards that comprise the master section (two 8-knob single channel Monitor strips and one stereo Master strip). There are various chips missing from the Master/Monitor boards and also the channel strips. I assume this is to get everything out of the circuit except the preamps and the buss outputs so it can be used as a front end for a DAW or summing mixer. I want to use it for mixing and recording, so I want it all back to working as-designed and get me some stereo output.
All the channel strips have had the chips removed from the Pan and Echo sections. The remaining chips in the channel strip are all pairs of "AB TL071CP" (2 8-pin chips per socket, 7 sockets). Would I just use more of the same chip to fill in these empty sections of the channel strips or would they likely require something else?
The 2 Monitor strips (8 volume knobs, plus a master knob and a fader) are filled entirely with "ML741CS 7343" chips (2 8-pin chips per socket, 4 sockets per board) except one is missing from each one board next to the master volume knob. Ditto above, is it likely that this is the same as all the others?
The stereo Master strip has one 8-pin "777TC 7532" chip in the first 16-pin socket, and then the remaining 3 sockets are filled in with "AB TLO71CP"s (3 more sockets, 6 more chips). Is it reasonable to assume that I just need another "777TC 7532" in the top socket?
Should I replace all the chips while I'm at it? Some of them are kind of expensive from Mouser. Most of the chips in the board are marked "Malaysia". I've found similar chips on Digikey but I'm not sure if I need to find the exact same ICs (as-marked) or if they just need to be the same type.
Oh, also the power supply hums kind of loudly. Is this a simple fix like a cap job or more likely something major? Is the p/s a good thing to upgrade/replace?
I can post pics of this beast if anyone's interested. Thanks in advance for any and all help!
