G
geoffmuso
Hi all,
I'm relocating my setup to two empty rooms seperated by a solid, brick partition wall, however I'm pondering at the moment what would be the best way of getting all the cables through from the control room to the live room. Since I would like to be able to have the option of controlling the PC from either live/control room, I will need a hole in the wall big enough to fit the plug of a monitor extension cable (maybe a DB25 as well) which might mean something like 4-6 cm diameter. The hole would go through to a fitted cupboard on the control room side, which I suppose I could use to block the gap as much as possible, as well as putting rockwool into the hole itself, but is this a feasible idea? How much will this affect the trasmission of sound from the control room to the live room? Any good suggestions for either the making, or the soundproofing of the hole?
Many thanks in advance,
Geoff.
Geoff.
