Z
zone_ahead
I have a new problem I have been experiencing more and more lately.
Here's an example. Last night I had an audio track that I set a volume envelope on. I faded it in over about a measure to the peak volume. Now when I would play it back, It did not recognize the volume change - actually it didn't play anything until the envelope reached it's peak, when it would "kick in" all the sudden and play fine. When I faded it back out at the end of the wave file, the evelope worked fine and faded like it should. Several attempts at adjustment and playback did not help any.
Now here's the deal - closing and reopening Sonar, solved the problem and when I would hit play after reopening the volume faded in, as it should. But then a little later it started doing the same thing and I had to save, close and reopen to start working again.
This has happened with all types of envelopes on all types of audio tracks, including those with my DXi's and VSTi's. Volume, pan, or automation from an effect, it doesn't matter. Now this happens often enough to be annoying, but not often enough to pinpoint anything that I would be doing wrong.
Maybe related, but probably not, I have also been having problems with the GUI switching between screens. A lot of the time remenants of the console will stick and remain when I pull up the track view or piano roll, or vice versa. Also when I open and close my VST/DXi's This happens A LOT.
I'm wondering if a fresh install is in order, or if somebody has any ideas? Thanks.
Sonar 2.2XL
WinXP Home
P4 2.4Ghz
512 MB RAM
SBLive! - yeah I know
Sonar 2.2XL
WinXP Home
P4 2.4Ghz
512 MB RAM
not the dotted line.
