P
PCFour
I was never sure but what exactly does hiss come from, the mic, the room ur in, the sound card...im just very curious i never really knew, and what is the best way to get rid of it. thanks
DJL said:noise... may times from amplification.... use better gear.
PCFour said:I was never sure but what exactly does hiss come from, the mic, the room ur in, the sound card...im just very curious i never really knew, and what is the best way to get rid of it. thanks
DJL said:And many times cheap gear is noisier.
EDIT: Added... and remember, they were asking about "hiss" (white noise) not RFI and etc. PS... but thanks for trying to help... and your right "using excessive gain in the signal path" and "overuse of compression" and etc can cause noise.
But not typically as white noise (hiss).Phyl said:RFI typically manifests itself as noise.
DJL said:But not typically as white noise (hiss)..
Sure there is... but typically you hear the station rather than white noise... and many times cheaper gear is cheaper because they cut cost by cutting things like filter caps, shielding and etc which helps stop RFI.Phyl said:Incorrrect - do a google search and you'll come up with plenty of references which link RFI and white noise (hiss).
