Higher Quality Speaker cables
  • Thread starter Thread starter traw
T
traw
I have some KRK Rokit 5's and want some hq stereo cables cause this mono setup is not going to cut it.
A speaker is mono. Two speakers can be stereo.
There's no such thing as a stereo speaker cable... It carries one signal. I mean, you can buy them in pairs, I've also seen them loomed for the first meter or so, yada, yada... But a speaker cable is a speaker cable for the most part.
I have some very weird speaker cable sets... I sometimes use 4 conducter speakon conectors to have both left and right going +1 -1 +2 -2through it and use a break out box with 2 conducter speakons and 4 conducter speakons.
the reason is i can just run one cable instead of two from the amp rack. then break it out.
If you have passive monitors .... lets say 4 you could use 2 2channel amps and then wire the rack with 8 conductor and then have a break out box to feed the monitors.
works for me. :D but then im odd in the way i think : :eek:
maybe he means balanced TRS mono cables, instead of "stereo." ....if that's the case, any music gear website will sell several brands and lengths of these.
