Stratomaster
Active member
While I was mixing last night-I was referencing an Rem album,(Green) while this isnt the greatest sounding album going-I did notice as with most of the things I refernce against-the biggest difference is the high end on EVERYTHING!-Not only cymbals-but guitars and especially bass guitar and kick drum.
I guess my question(s) are:
Is this pro high end sound a product of great recording technique? Great rooms, instruments and mics? All of the above is my guess.Though I've heard some home recordings that sound pretty close.
If say one was lacking in any of the above-when would be the best time to add this high end eg: I could eq my signals while recording(dont really like to do this) mixing-seems like the time to add this high end if its not there but-Ive been reading how any volume adjustments screws with your bit accuracy so they should be kept at a minimum. Or should it be added in the mastering stage? How much can you add that isnt there to begin with?
Can anyone identify this particular high end region?-seems like its at least 10k and above that makes that airiness that really makes some instruments come alive.
Thank you for your time and responses.
Strat
Strat
Getting a good, clean sound that won't grate on your ears when you boost the high end is actually pretty inexpensive to do in terms of the gear you need to get you there.
How bout that oktava mc012? isnt that the one GC is selling 2 for $150? Just got my RNC too-woo hoo-getting there little by little heh-You rated?(chess)
