alibish
Hotrod Cadet
The production sounds very good, and I wish my singing was as "bad" as yours
Not my style of music, but very impressive.
There are a few ways to get patch settings out of your POD 2.0 (which I agree is a great toy).
You can use software (either SoundDiver which comes with the POD, or PatchWizard, which is a bit better and fairly cheap). You have to connect your PC to your POD via MIDI, but once that's done you can play with different settings *much* more easily than with the POD alone. You also get a bit more control over some detailed parameters you can't get at through the knobs and buttons.
Or, you can use the manual method (detailed on page 6.2 of the user guide). Basically you press *and hold* the SAVE button, then turn any knob. The wee arrows light up to tell you which way to turn the knob to get to the current setting. When both arrows light up, you're there! I think it should work for all the knobs, but not the Tap Tempo setting.
Cheers
Alastair
Cheers
Alastair
