Help With Soundcard
  • Thread starter Thread starter Miseria_Cantare
M
Miseria_Cantare
Ok, I have a Delta 1010LT.
The problem is that, normally when I record (when I was using the audigy 2) I had my mixer plugged into the line input, and headphones plugged into the line out, and I could control the volume of what I was hearing, so I could hear what I was actually playing as I was recording.
Now, with the Delta1010LT, I am trying to do the same thing, have headphones plugged in outputs 1+2 (using an adaptor) and the mixer plugged into inputs 3/4.
But I can't turn the volume up loud enough for what I'm hearing. there is no 'volume control' for inputs 3/4 that I can use to make this louder for me to hear as I'm playing.
Can anyone help?
The Delta's outputs are line level. You need to run the Delta's outputs back into the mixer and monitor from it's headphone out.
Or get actual Powered monitors and plug them into the Delta"s outputs...
You could also just get a basic Headphone amp and you plug into the Delta"s outs.....
Cheers
