J
jsegovia
I'm a proud, new owner of an FMR RNP/RNC combo. I'm trying to get male vocals similar to the sound the Beatles get on 'Revolver' and the 'White Album,' very up-front, very open and full throated. I'm using a Rode NTK into a yamaha AW4416 DAW.
Any recommendations on settings with the RNP or RNC to get closer to this sound? I realize the RNP just has gain settings but are there any tricks I'm missing to get a bit more drive out of it, without any distortion?
And can anyone recommend some RNC settings to produce a very compressed sound with lots of presence? I'm experimenting with both normal and Supernice mode and I just hasn't found it yet. I'd like to be able to scream without clipping, and have the quieter, subtler parts come up louder in the mix.
How about a fairly fast set-up. Medium ratio, say 4-6/1, and a quick release, .2-.5, and a bit fast on the attack, in the 6-40ms range. The attack time will have about as much effect on the amount of gain reduction as the threshold. As you work toward the slower end, it will grab later leaving in some edges. The fast release gets it back up in your face quickly. SuperNice takes what ever you set and slows it down a knotch. But I think you might also loose a bit of edge there.
