D
daydreamer
Hi,
Andy here, new to forum...
I've spent a fair amount of time over the past year researching and building a a humble recording setup. Lots of research, and some impulse buys. This ML-52 II was one of the latter...unfortunately.
Basically, I saw it on ebay advertised as being modded with the Lundahl transformer and like the look of it and threw down 300 bucks US. I got it, plugged it in and it sounded bad, scratchy and bad. But it did work to an extent; there was a signal.
I openned it up, as you do, and found that one of the two ribbons was real slack. Damn. USPS can't really be blamed, 2.5 microns wasn't going to like international post I guess. So to cut to the chase, I get more 2.5 micron foil, shape it and install it. Not a bad job if I do say so, looks nearly indistinguishable from the other untouched ribbon. Doesn't touch anywhere, roughly same tension. All good, I thought.
I go to plug it in, (I'm using a Triton Audio Fethead Filter to get the extra gain needed) and..nothing. Absolutely nothing. change leads, remove filter, change to another lead, volume cranked, nothing.
I really don't know enough about these to troubleshoot any further, I'm getting into electronics, but I'm a complete noob in reality.
any ideas on what could have gone wrong, and what I can do?
thanks
Andy
aeune is online now Report Post Edit/Delete Message
thanks
Andy
it is being held with solder..) I think I need to recheck/ replace the insulation between the ribbon holders, magnet and frame. It is some sort of orange wax paper which could be too old.
