Chris Tondreau
Member
Hey there;
I have a quirky problem (yes, music gear related
I typically run a mic or a bass into my Behringer Composer Pro compressor (very moderate compression usually), and then into a Peavey TMP1 mic pre. From there, the mic pre goes to my Delta 44 sound card. When I do it this way, I have to set my level on the TMP1 so that it bareley registers on the meter (level maybe at six, but the level (db) meter registers at -6) If I run any hotter than that, I get clipping at my soundcard level meters. I don't actually HEAR the clipping, but when it goes full red, I get nervous.
I'm under the impression that the ideal would be to run the TMP1 with an output level measuring +6 to +12 (yellow range) for a good hot signal, but that would pretty much blow the doors off my sound card.
I've considered operating levels. The Composer Pro is set at -10, and the TMP1 doesn't have any way of setting this. (I don't know what the default of the unit is.) I monkeyed with the operating levels in the control panel of the sound card, but I've got the best one. The others are hotter.
The funny thing is, I'm pretty sure that this has something to do with the compressor, as without it in the chain, I CAN get a pretty decent level on the preamp.
Any suggestions?
Chris
);I typically run a mic or a bass into my Behringer Composer Pro compressor (very moderate compression usually), and then into a Peavey TMP1 mic pre. From there, the mic pre goes to my Delta 44 sound card. When I do it this way, I have to set my level on the TMP1 so that it bareley registers on the meter (level maybe at six, but the level (db) meter registers at -6) If I run any hotter than that, I get clipping at my soundcard level meters. I don't actually HEAR the clipping, but when it goes full red, I get nervous.
Any suggestions?
Chris
, but then thought that a compressor can still work on a signal that might not yet be at line level, and may be able to get a more controlled signal already - even before it gets as far as the preamp, for more control all the way through. What I hadn't considered before, though, was that my preamp, being a tube pre, wouldn't likely be adversely affected by a signal that might result in nasty clipping like in A/D converters, and I hadn't considered that I'd run into the quirky problem that I described.
