R
RecCordEr
I have digital voice recorder Olympus WS-200S, and have problem with it, when i hold it in my hand while recording i always got noise on recording when i move my finger on uint, it picks up every scratch and i can hear how it records buttons i click, and its almost impossible to put it in the pocket because theres so much noise on recording if you even slightly move.
I came across solution to buy external mic, they offer Olympus ME-15 Microphone (mono), but descriptions saying "To record your own voice or from other people nearby." i actually want to know if theres better choice of mic that can catch sound from larger distance and wont record that much noise if i scrath it a little while holding or wearing.
Dictaphone specs:
Input Level: -70 dBv
Sampling Frequency: Stereo 44.0kHz, 64kbps /Mono 44.0kHz, 32kbps
Overall Frequency Response: Stereo :100-15,000Hz/Mono:100-12,000Hz
Microphone jack (stereo): ø3.5 mm jack, impedance. 2 kΩ or more.
First one Mono, Price 25$.
Type: Electret condenser microphone
Directionality: Non-directional
Frequency response: 100 - 12,000Hz
Sensitivity: -42dB at 1kHz (0dB = 1V/Pa)
Output impedance: 2.2kOhm
Power supply: Plug-in-power system (1.5V . 10V)
Cord length: 1m (3.3ft)
Output Plug Type: 3.5mm Monaural mini-plug
Second mic Mono. Price 10$
type: electret microphone
frequency response: 20 - 16000Hz
sensitivity: -65 ± 3dB
output impedance: low
directivity: omnidirectional
cable length: ± 4m
Third mic Stereo, the only con it comes with bettery holder which is somewhere at middle of cord. Price 25$.
includes a windscreen to avoid "pop" noise and a low-noise cable to reduce signal distortion
mono and stereo operation selectable
transducer principle: back electret condenser
frequency response: 100Hz - 16kHz
pick-up pattern: cardioid
sensitivity: -68 dB
impedance: low
signal cable: 3m with 3.5mm or 6.35mm stereo phone plug
power supply: 1 x 1.5V AA cell (type UM-3)
P.S. I have no idea how to read this specs can someone give me advice which one can pick up sound from greater distance?
Dictaphone specs:
cable length: ± 4m
sensitivity: -68 dB
impedance: low
