Shailat
Re: Re: Re: Re: OK
No.
I mixed with in the computer (just simple panning and levels), and monitored via the Main left and right outputs, then I mixed the same mix by sending from the 001's 8 outputs( so to avoid summing) to the board and acheived the same mix using the mixer, and monitored the results so I reached the same mix meaning - I made sure the panning and levels were exactly the same (not the quality) so that when I would A/B them, a different balance would not effect my desicion.
Every software has a different name for his - to bounce in PT means to take your multitracks and process them to a single stereo wav file, on your HD. So 11 tracks sitting in the software are mixed by panning and levels and then I created a single wav file by bouncing them to the HD.
PT gives you several options of bouncing acourding to the level you might want to get.." Tweakhead" is supposed to be the highest quality. Were as if you were bouncing say a recording of material that the audio quality is not as important to you, you have other faster options to bounce.
All in all....I'm not saying that people should ditch digital.
I couldnt do so myself knowing some of the great advatages you get using Digital. It's the combination of the two and knowing when to use each will get you the best results.
But with Digital all the way (in these days) I have yet to be trusty of.
I have to point out the the difference of sound to some of the users here might not make so much of a difference as they might claim "for me the difference is not so big as to make me feel its worth ditching Digital". And thats ok if they reach that conclusion
as digital has brought them several options they could never reach with out a DAW as well as getting some realy high quality sound.
But for others It can be the difference of the world.
Each to his own.
Ethan Winer said:Shailat,
I have to admit I'm more confused than ever. The first part of your last message said you mixed once within the computer and then once again through separate digital direct outs through an analog mixer. You said these two mixes were identical. This has been my point all along, that unless something is actually broken, there should be no meaningful difference.
No.
Then you refer to a "bounced" mix which I don't understand:
> This part was amazingly nasty.... I took the 11 tracks and bounced them to a single wav file using the tweakhead option. <
To me, a bounce is a one-to-one transfer. You bounce a stereo mix from here to there. But how do you "bounce" 11 tracks to a single wave file without mixing them? Or do you mean all 11 tracks were in series, one after the other? Also, I have no idea what the "tweakhead option" means.
Each to his own.
And the 001 converters really do suck
