Track Rat
Just Your Average Sized Member
Post an MP3 of that please.
You're missing my point. You're arguing that digital is a "better" recording medium because it's more accurate. I'm arguing that a recording medium should be judged by the end product. If a band or a record achieves its aims better by using recording medium A than by using recording medium B, than recording medium A is the better recording medium for that band or record. Because, and I think we can all agree on this, what's important is the music. Of course this is very subjective. Perhaps, to your ears, digital always sounds better than analog. Perhaps, to Larry Crane's ears, analog always sounds better than digital. To my ears, analog is good in some situations, and digital is good in others. What I think is really sad is that soon we won't have any choice. Digital will be all that's available.Yes, I distinguish between accuracy of recording and adding an effect! If you want to further your point you'll also have to define "musicality." If you consider added distortion, flutter, tape hiss and modulation noise, and a skewed frequency response to be "musical," there's nothing I can say to convince you otherwise.
What crappy old equipment are you talking about? Trident desks? Universal Audio compressors? Neve preamps? What? I sure don't see "crappy" equipment going up in price.Thus began the rapid rise in price of crappy old equipment
I don't think tape compression is a "failing" in every instance. I don't think the bass response of analog tape is a "failing". It can improve the sound of some recordings. How could something that improves (and of course I realize that "improve" is a very subjective thing) the sound be a "failing" when you're talking about audio? To quote Joe Meek, "If it sounds good, it is good." And yes, I know that quote is tossed around quite a bit.Again, the real issue is separating the quality of a recording medium from some perceived benefit caused by its known failings.
Have you ever taken a college logic class? What does the original intent or "benchmark" of Ampex's (or whoever's) engineers really have to do with anything? Essentially what you're saying is, "Accuracy is the proper aim of a recording medium, not because it fulfills the purpose of the person who uses it, but because the person who orginally developed it felt that should be the case." SO WHAT! Thomas Edison was really upset when people started using his invention, the phonograph, primarily to play back music, and not what he originally intended it to be used for, speech. Does that mean that, from that day forward, everyone who used records to record music was wrong? I appreciate analog, and I feel it is the ideal medium for certain types of music, despite what it's original inventors felt was the proper end of a recording medium.Do you think that in the early days of tape recorders, engineers compared different tape formulations and head geometries to see which sounded cooler? No, the standard benchmark has always been to play back what was recorded as accurately as possible.
If you could somehow prove to me that that's the "real issue" than I'd agree with you. Again, you're presupposing the point you're trying to argue. Circular reasoning doesn't work. Also, you try to deride the benefits of analog by saying that they're "perceived". All sound is perceived. It's nothing but perception. That's all we have to go by. It's sound!Again, the real issue is separating the quality of a recording medium from some perceived benefit caused by its known failings.
BrettB said:A musician has to spend money sometimes![]()
An engineer's job IS to worry about "the tech specs of electronic floatsum and jetsum".... a musician's job is to abso-fucking-lutely say something musically.Jack Hammer said:Do you fucking people ever make any music or do you just spend your time pouring over miute little differences imagined or otherwise in the tech specs of electronic floatsum and jetsum. Wow...In my opinion, the real reason you are having this "debate" is becuase you have abso-fucking-lutely nothing to say musically.
I've been trying to separate analog tape as an effect from its recording quality. If you prefer that effect, and know of no other way to get that effect, then you are correct that it is "better" in those cases. But it seems to me that a 3 dB. boost caused by head bump is the same as a 3 dB. boost added by an equalizer. And for a lot less money and hassle.
If using 24 bits did not require half again more disk space and CPU and drive loading, I'd be all for it. But don't say nobody believes 16 bits is better. Just today there is a (surprising) thread over at ProSoundWeb where several people claim they prefer the sound of 16 bits. I took the comments to be similar to preferring the sound of analog tape, where a slight dirtiness is sometimes desirable.
https://homerecording.com/bbs/showthread.php?s=&threadid=42525 read the first two posts by sonusman but don't pay attention to the BS, just the facts. Its a pretty good explanation of how EQ qorks quickly, without refering to how it actually screws with phase, SPL, and distortion. Those three components of the sound will be different with each "3dB boost" applied to the signal. Tape doesn't have a bell, or a shelf, but a shape depending on the head, the mackie EQ depends on parametric or shelf, and i couldn't tell you the specifics of an SSL, but i guarantee its different from a mackieAnd the difference between those is ... ?
. EQ will sound different depending on analog/digital application and which algorithms/brand of board you use.
