I
ifpo238
Gurus,
I'm ready to upgrade my home recording studio, and I've decided to purchase SONAR XL and an Aardvark Q10. I plan to buy another computer, too, but I'd like to get your advice on what I should build.
I've also got a couple of mics and a Roland XP-30 synth I'll want to connect to the Q10. I hope to be able to let SONAR control the XP-30, and I'd like to be able to use the XP-30's keyboard to control the software synths that ship w/ SONAR XL. I'm mostly a guitarist, though, so I'll be recording acoustic and electric guitars and using the synths mostly for synth, bass, and drum parts when I can't find loops to do the trick for me. So, hopefully that gives you an idea of what I'll need the setup to do. Questions:
Am I better off with AMD or Intel? Is there a difference? I'd prefer to avoid any incompatibilities on the front end. Am I better off w/ a single 1.4 GHz processor or w/ 2 700 MHz processors? What are the trade-offs?
RAM: The FAQ says 64 MB minimum. I know I want at least half a GB, but should I plan on more? Which recording/playback/automation functions are processor-bound and which are memory-bound?
WDM drivers: When will the WDM drivers for the Q10 be out? As I understand it, I need WDM drivers for effects automation to work well, and to be able to control the software synths from my Roland keyboard. Will I need WDM drivers for the Roland XP-30? Are they out?
Dual video monitors: I've never used dual monitors before. What do they give you? Should I splurge?
Drives: I know I want one hard drive for the system/software and one to record audio to. Should I consider a third drive for the software synths?
Audio monitors/speakers: Can I use the Roland speakers that I currently have plugged into my XP-30 for this, or do I need to buy studio monitors? Any suggestions on which to buy for a small bedroom studio?
What else should I take into consideration?
Finally, can you recommend a company that will custom build this machine for me? I'd prefer a reputable place that has experience building digital audio workstations, and preferably one that has dealt w/ Cakewalk and Aardvark in the past.
Thanks so much for your help! This is my first time building a machine to dedicate to recording, and it's a bit intimidating...
-j
-j
