L
little z
Ok, here we go... I need to know which direction to go in once all tracks are recorded (dry with no fx or processing) and I want to mix down to CD-R. I want to add compression to the overall mix so as to get a little better control and even sounding mix going, but as some of you know, adding compression after the track is recorded is a bit hard on the Fostex FD-8 without having a patchbay. I just want to add a bit of tightness so that I may get a hotter level to CD and possibly a better sound altogether!!!
If there is any other info any of you might know of that would aid me in this, ALL suggestions are welcome as I try to keep a wide open mind in getting the best results possible!!!! I thank you all and will see ya later!!!!!!!!!!!!!!!!!!!! Little Z (STEVE)
