P
pitbull34
Okay Guys I need some help?!!?!?!?! I have been recording two years with my vs 880. I have pretty much learned how to record by trial and error, I have finnally learned to control my voice, and have it sounds great! However there are a few major problems, let me start with the drums,(i'll make this a short as possable) I am recording with a drum kit in my xp 50 I use sound filters and little tweaking to make them sound just like the real thing, however when I record them after the mix is complete the drums sound a little weak, I have tried eqing and it sounds better but there is something missing!?? Then I try just to use a compresser without eq and it sounds way better but there is something still missing. I have tried no eq or comp and just raised the levels and it still is missing something!!! I have tried both at the same time and it still is not happening!!!! Help!!!!!
Now about the guitars!!!! MY mix will sound pretty good until I add those damn guitars, I have recorded direct, through an amp, direct with an amp simulator, eq, and no eq, and it just doesnt sound good either way!!! The only thing that is working right now is layering I will record two tracks seperatly with the mic then pan left and right, then I will record (again two seperate tracks left and right) direct with a low fi processer and it sounds 80% better but the mix still sounds empty what do I need to know to have a great mix? I have taken courses and I have even gotten advice from different people, I am missing just some little something but I just cant figure it out!!!!!!!
