help Ethan's modecalc.exe can't delete it
  • Thread starter Thread starter HangDawg
HangDawg
HangDawg
bUnGhOlIo
I don't know what the hell is going on. I downloaded this the other day and placed it on my desktop. I ran it, now I'm trying to delete it. It say's the file is being used and can't delete it. What the f!@# It is not being used. Rebooting hasn't help either. Neither has shuting down all running apps/process/services I can't get rid of it.
[Edit]
I just downloaded it again into C:\temp and didn't run it. Can't delete it. Says the file is in use. What the F@!!@ $#@
Hey HangDawg - Try booting into safe mode (f8) and try to remove it from there..
Strange,
I just deleted it - restored it - deleted it again - without any issues......
it sounds to me like you have an issue larger than modecalc.
ROd
Rod Gervais said:
Strange,
ROd
Maybe so, but what? I'm sort of knowledgeable when it comes to computers. I'm a network admin (8 years) and a certified DBA. I've never seen anything like this happen before. I'm stumped. I'm going to try a DOS boot disk and go from there I guess.
Dawg,
> It say's the file is being used and can't delete it. <
ModeCalc is a simple DOS program, and it doesn't get installed or do anything else to your computer. It just sits in a folder on your hard drive waiting to be run. I agree with Rod that your problem is elsewhere.
--Ethan
I know this. I just can't figure out what would cause this. It's mighty strange to say the least.
Being an admin, I thought you would have checked the file's permissions/ownership first...
I didn't post all the things I did do especially the really obvious ones like file permissions. But thanks for the suggestion none the less. It's still there. The only thing that I remember that was similar to this was a file name with an invalid character.
not sure what os you are on... go to a command prompt run attrib on it and then try to delete from the command prompt. go to the dir where it is and try attrib -R -A -S -H {filename} that will remove any additional properties that might possibly be causing this issue. then try del /F {filename} .just my 2 cents.
No dice.
I did finally get rid of it using a utility I found called copy lock. It aparently uses api calls to delete files even if they are being used. A reboot was required but it's gone. I've never had anything like this happen before on this or any other machine.
Mode Calc Nightmare
I'm having the exact same problem. I'm a big fan of Ethan's pages and downloaded Modecalc when I was writing a physics module on my Sound Engineering course.
Now I'm stuck with it for all eternity... :confused:
> Now I'm stuck with it for all eternity... :confused: <
I have no idea what the problem is, but it's not related to ModeCalc. It probably has to do with permissions and administrator settings. You could always boot into DOS from a diskette and delete it manually.
--Ethan
Copy Lock is now called Locked Files Wizard and is available as freeware - you can download it here:
http://noeld.com/programs.asp?cat=misc
Rod
