stashmanguitar
I'm looking to build a room to record ADR & Foley but need a little bit of advice on getting there. I would need the room to be as dead as possible as I will be using very sensitive mics and pres at very high levels to be able to record the smallest of sounds. This room would be in my basement so I would also need help in figuring out how to isolate sounds from the house being audible in the room and vice versa (if possible).
The usable area's dimensions are 38' x 12' x 7'. I plan on dividing the space in half into a recording area and control room. The ceiling and walls are drywalled and the floor is currently linoleum tile on concrete.
I've already found a bunch of useful information on building mixing rooms searching on the forum, but I can't seem to find anything on rooms for recording sound effects. All advice, if any, would be extremely helpful.
Holy moly...doesn't it take something like Two Leaf Masonry to achieve that John? And if so, what about the ceiling/roof or floor above? What's that take? 5 or so layers of drywall or such?
Btw John, were the rooms built on TOP of the floating floors or did the floors float BETWEEN the partitions? And if they floated between, assuming TWO LEAF partitions, did the partitions have their own footings? Just curious. Always open to learning the ways pro's do these things.
