Shazzhy
Hi everyone,
With the band I'm playing with, we started to *try to* record our songs yesterday. As it was the first trial, it was more to define an approach than to have something in the end of the evening.
We quickly came to the conclusion that we would need a headphone amplifier to use as monitors while recording.
I started looking at what exists on the market, seen the Behringer HA8000 but also read quite some reviews about the bad quality of sound (although the ratio price/quality was not that bad as it is very cheap), I then continued to investigate and found out the Presonus HP60 which seems to be a decent choice. More expensive but also more quality.
I then gave a call to me preferred music shop and the guy told me about another one: the M-Audio AP6 which seem to be the same as the Presonus (apparently M-Audio and Presonus products are done in the same factory) but I tried to Google it and cannot find any reference of it. Has everyone ever heard of it?
Just a word about our gear: We are 5 (2 guitars, 1 bass, 1 drum and 1 singer), so we need more than 4 headphones output. We record using a MacBook Pro on Garageband and using an Alesis Multimix 16FW. We do intend to record first the drum track using a Roland TD-4K plugged into the Mac (we'll probably record an acoustic drum later one but our room is not that good at the moment), then we'll record guitars and bass at the same time and then the voice. For monitoring we'll need that headphone amp. Any suggestions, remarks or potential issues on this approach are welcome
Now more specifically about the Presonus HP60. Would you recommend it? Any bad experience with it? From what I could read on this forum and others, it looks really good.
Now, I see that there are 2 inputs. Input A and Input B. Apparently, they are mainly used to input the mix and input the click. Which is a perfect solution. With my setup described above, I do not picture yet how I can do it. Basically, I would need to send the mix to Input A (so from the CNTRL OUT of the Multimix) and the click of Garageband to Input B (This part, I have no idea how to do).
Also, I see that each of the 6 inputs also has Stereo Ext.in, allowing a different mix per headphone. On this one also, I do not figure out how to do. Does it mean that each instrument will have to be plugged into the mixing console and then the mix to send to input A and on top of that, each instrument of each musician also sent to Stereo Ext. In so that each musician can mix between his own sound and the mix?
Any recommendation for any other headphone amp will be very appreciated.
Sorry if I’m not clear in my explanations, it is still quite new to me (and I'm still French speaking - btw, I had good laugh with your answers on the other post) and not always easy to explain. But fortunately, I post in the Newbies forum !!
Thanks for reading.
Thanks for reading.
