stainlessbrown said:
Most of my headphones are Sony V600 - 900's so loading is fairly consistant but (as Gilliand pointed out) a variety of headphones will give everyone different "mixes" both EQ and level)
A couple of you have commented on the issue of sound level as associated with headphone impedance. That's certainly something to be aware of, since lower impedance headphones will draw more power from the amp and (assuming the same sensitivity) will produce more sound. But that's not the issue that I'm trying to point out.
The problem comes if the TOTAL impedance seen by an amplifier goes lower than the amp can support. In that case, the amp itself will begin to distort heavily, with the result that the sound in
all of the attached headphones (regardless of their individual impedance) will produce sound that is unusable. Not just slightly distorted, but so severely distorted as to be unlistenable. Some may still be louder than others, but that doesn't matter much if the signal coming out of them is garbage.
That's the problem that I had with the Rolls unit, and there are probably others on the market that will run into trouble as well. The problem is that you may not discover this problem until you've had the product for a while, so it's a good idea to test any new headphone amp with a collection of low-impedance headphones to see how it behaves.
While there are still some headphones on the market (like Sennheiser) that have impedance that is well over 100 ohms, more and more are coming down to the 50 to 80 ohm range (like Audio Technica and AKG). And then there are the Sonys, at 24 ohms, which can quickly bring an amp into its trouble zone if you hook up multiple pairs.
