H
Harvey Gerst
But that wouldn't explain why it would work in mono with the eq set flat and panned to the center. And it does work fine in mono.crazydoc said:Well, in mixing you have at least two options to distinguish the two signals.
One is stereo separation, where you can pan the two signals apart in the stereo field toward different speakers, helping to separate any conflicts in the signal.
The other is EQ, as is done where there is masking, slightly boosting or cutting different frequencies in two signals of similar frequency range.
Actually, it works fine.You can't do this with two instruments plugged into the same amp, unless each input has separate frequency controls (as some do - I don't know if they'd be adequate for this purpose though).
It doesn't work like that. Theoretically, you would think that there would be cancellations and phase beating, but even with two people playing identical chords at the same time, even using identical instruments, there is enough difference to avoid phasing problems.Maybe phasing was a bad term to use, though I think that the phase relationship of the signals plays a part in it. This is nothing to do with two mics on the same signal - rather it is mixing two similar signals with constantly changing volume and frequency relationships, that at times are going to reinforce and at times null.
Ahhh, there, you would have a problem; if two guitars played the same single note at the same time, yes, you could have phase issues, just as you would with the same two guitars plugged into two channels of a mixer and panned to the same place, but not usually with plugging two different instruments into both jacks. It's normally a non-issue.When you tune a guitar by beat frequency, the two string signals are going through the same path. If you were to tune two guitars plugged into the same amp to each other, could you do it by beats? If so, then I think my premise in the above post is true. If not, then it isn't.
There ya go; try it. You may have just added a new trick to your engineering bag.Then again, I could just be full of shit. I guess I'll just have to try it out.![]()
