Well, I have to be honest.
I thought that the flat clip had a lot of body, and sounded better than anything I'm about to achieve right now. However, it didn't have much presence and was kind of dull and flat. Not a lot of subtle nuances when I compare it to other male vocal sounds that I like. (not refering to the actual singing, the singing was cool)
Then the EQ'd clip had more of what I thought the flat clip was missing, but sounded really grainy. I'm not sure how you EQ'd or what EQ you used of course.
Lots of factors involved here. Your voice is a lot different than mine. I'm not sure what you actually record on? Also, I'm not familiar with the dmp2. Then there's the issue of mic placement and blah blah.
Cyan, I think you mentioned that you liked the V67 better than the 414...what would you think of recording a similar clip with the 414 for reference. Or, better yet, if you still have access to the 4033 I wouldn't mind hearing it (couldn't tell if you meant that you actually owned the 4033 or what)
Thanks very much for your input!
Slackmaster 2000
