guitar strings
  • Thread starter Thread starter WEBCYAN
WEBCYAN
WEBCYAN
i just put on a new set of strings for my yamaha acoustic. I had the original strings on for 7 years! Needless to say the difference was HUGE! Ive fallen in love with the guitar all over again.
Im wondering...the are many different "kinds" of strings out there. Im thinking about getting new strings for my electric. Does it really make much of a difference what kind you get?
I want a warm silky sound. Not muffled and bassy. Clear and sharp but still with a great deal of silkiness and warmth to it. Not to shearing....
any reccomendations?
ps: dont comment on my spelling...i know i cant. :)
I can't believe you haven't changed your strings for that length of time.
One of the key fundamentals for better tone is new strings (well I personally like it when they have been worn in for a couple of days best).
Depending on how much you play you should really be looking to change your strings say once a month or two at the most.
There are many different strings out there. For your elecetric, IMO D'addario are cheap and chearfull, Ernie Balls are probably the most popular but any strings from GHS, Dean Markley etc are good quality/going to be fine. I Use DR's now; there a little more expensive but last longer (don't know about 7 years though). For your acoustic I'd recomend some Martin Sp's.
Remember the higher the guage the better the tone (generally speaking) but the lighter-the easier to play.
Buck, I can't beleive we agree on strings!!
Them Boomers is the cat's pajamas!
You better get wire cutters, if you ever want them to break!
GT
what do you mean by better tone?
More sustain? More fullness?
I love GHS Boomers .010's on electric and GHS Contact Core for acoustic. Also the Contact Core style for Bass guitar.
I played the .009's for years but I have a heavy right hand and broke strings too much. Went up to the >010's and stopped breaking strings.
Buck, stop messing with the poor guy :)
Better tone means better tone. You'll get it one day, just keep playing. For now, you might experiment with various brands of strings until you find one that you like. You'll know you like em because you'll like em, simple as that really!
I play Ernie Ball Power Slinkies (.11-.48) and would recommend anything in the slinky line. Since you seem relatively new to the guitar, I'd recommend either Regular Slinky or Slinky Hybrids. The regulars are 10's and the hybrids are a mix between regulars and power slinkies (fatter on top, lighter on bottom). Don't play with lightweight strings too long, you'll just be doing yourself a major disservice, no matter how difficult heavier strings feel at first.
As far as changing your strings... You should feel when they start getting nasty. They'll feel ugly and they'll sound even uglier. Hell, they'll even LOOK ugly. If I let it go for a long time, I'll probably change the strings on my acoustics once every couple of months. With heavy playing, however, it'll be as often as once per month. Now that's not because they don't need changing more frequently, it's simply because I'm lazy.
Now the electric is a different story. I'll probably change the strings on my les paul at least once a month, or at most every two weeks. Well that's not true, if I'm playing hard I'll break as many as one or two strings, meaning a string change every other day or so. But that's not normal "home studio" playing.
One product that you absolutely NEED in your case is a bottle of magic substance called "Guitar Honey". I'm not sure what the shit is, but I'm pretty sure it's magical. What you need to do is remove the old strings from you guitar, then with a damp cloth wipe all the nasty gunk off the fretboard. Make sure the fretboard is dry, then spray on a squirt of guitar honey between each fret (don't worry if it runs off). Once it's soaked, let it sit for about 30 seconds, then take a clean cloth and really rub hard between each fret until the board soaks up all of the magical substance. If the board feels completely dry to the touch after this, then apply another coat of guitar honey in the same fashion as the first. At this point, the fretboard shouldn't feel wet, but it should feel cool and a little bit oily. Now put fresh strings on your guitar. I guarantee that if you followed all these steps, you will literally have no choice but to take off your pants and have sex with your guitar...it'll feel THAT good.
And since you're changing your strings now, you might as well learn how to adjust your intonation. Despite what some people say, you can get it close enough with a regular guitar tuner and a small screwdriver. Do some searching.
Finally, if you've never had it done, or you change string weights, you'll want to take your guitar in and have it setup. They will adjust the neck, intonation, and action for you. The key here is to WATCH them do it. Once you kind of get a feel for things, you can make the adjustments yourself. The only thing I don't personally do myself is adjust the truss rod, because it can make this really nasty creeky noise that scares the crap out of me.
Just remember, most of your tone comes directly from the guitar which is just an extention of YOU. Amplifiers play a big role, but only if you know what you're doing in the first place. Same with effects, which are a new player's worst enemy.
Slackmaster 2000
I agree with the Slinky's. I use Supers. highly recommend the D'addario EJ16 for Acoustic. They sound great and not too bright. I buy em by the case.
Fangar
Ah yes, I too use D'addario mediums on my acoustic (not sure which kind, I just say "d'addario mediums" and the guy hands me the right pack).
Slackmaster 2000
They're great. I like the Ergo Pack (EJ16) cause you can fit many sets inside a guitar case, or a drawer. The strongs just come in a plastc baggie inside a cardboard sleeve.
Oh Yeah Weby,
I change strings prior to each recording session. Also prior to each Gig especially with my acoustic. I like the sound and feel of new strings, much like you have just discovered. Also, they PLAY in tune better (Once Streched out properly). Cheers
Fangar
I've been using boomers for many years,9s and 10s.But I'm not sure how much string quality can be attributed to branding.Someone told me once there are just a small number of big wire factories that job for everybody.Still,GHS gets my money.
Tom
Somehow I dont think he'll appreciate the subtleties of different strings if he didnt even notice that 7yr old strings sounc like absolute crap.
Sorry, couldn't resist :p
Web they are really just pulling your leg. Everyone knows that you can compensate for old strings with more EQ.
