Hi there.
I have a theoretical question here that has left me a bit confused after looking at a manual for the gsr24M mixer which shows the group channels as each having an insert point round the back.
Lets say you are sending several mono drum signals to a group channel on a hardware desk.
That group channel has an insert point. If you wanted to process the group channel through a stereo compressor and you used a standard insert cable from the 1 insert point on the group channel to the send and return on your patchbay you would surely only be able to feed the one channel of your compressor? Surely a group channel should have 2 insert points if it is capable of receiving a stereo signal?
Cheers
Nick
Cheers
Nick
