D
drBill
Thanks aus!!! That got it! A while back I had to reset my cookies for some sort of browser mess and lost it. Appreciate it!!!
bp
bp
Yay!!! (not that they failed, but that they run tests that are capable of failing54 of the mic pres failed their quality control tests.
Yay!!! (not that they failed, but that they run tests that are capable of failing)
By air, I hope.They are shipping only 900 out of the 1000 pc order and will ship the rest at their expense in about 2 weeks.
I wonder what they could possibly have done to cause half of them to fail... other than switching the 110/220 switch the wrong way, that is.
Usually failure rates above a couple of percent are caused by a design flaw, albeit often a minor, stupid one that requires more careful handling during assembly. About the only times I've heard of initial failure rates even remotely that high, it has been caused by a component too close to the edge of a PCB getting knocked loose during assembly.
That said, I could also believe it was a flawed connector design leading to a hand assembly mistake (mixing up the input and output of an EQ section because they didn't key them differently, plugging in a cable backwards because it isn't keyed correctly, putting the 220V fuse in the 110V side because it isn't marked clearly, and so on). All fairly minor design mistakes leading to assembly mistakes, in other words.
That said, if it is caused by a premature component failure, that usually suggests a manufacturing flaw (e.g. using a capacitor that isn't rated for the needed voltage/heat, using a diode whose breakdown voltage is too low, installing a batch of capacitors backwards, etc.). It could also be caused by a design flaw, though---putting an electrolytic capacitor where it comes into contact with a transformer (leading to drying out of the electrolyte and rapid component failure), putting a silicon chip in a location where the main board gets torqued when inserting and removing connectors, (leading to the chip breaking loose), etc.
I'd love to get a hold of the FA on those 54 units and find out how they failed. If it is caused by a premature component failure, a thermal expansion problem, etc., it might give us a good idea what sorts of problems we should be watching out for in the future with these things.
Of course, it could also be a non-catastrophic failure---doesn't meet the specified bandpass requirements or whatever---in which case it is probably just the normal quality variation of Chinese transformers. Here's hoping it is that.![]()
Or they could have just hired a new guy that day...I wonder what they could possibly have done to cause half of them to fail... other than switching the 110/220 switch the wrong way, that is.
Or the finish could have been off, or the guy with the screwdriver could have slipped, or they could have been stuffed with the components for AH's unitsD) or maybe the skiploader rammed them into a wall or maybe even they forgot to check the other 900........
What's the use of speculating???
What's the use of complaining about speculating???
Good point.
However, speculation causes some to become anxious. We have enough of that without adding to the fray.....
I'd rather speculate about who to vote for......![]()
The nature of the fault would indicate the level of concern that a small error rate lurks in the other batches . . .
