juststartingout said:
Ok, so you are not a Gibson fan, but that's cool. I wouldn't expect to find a good Gibson review on a Fender lover's forum.
About the bindings, I happen to like a bound neck and the way Gibson does theirs, but that's my preference. As far as the costs go to do this, I think you will find they are about the same. If you have ever viewed the Fender manufacturing video, you will find that they install the frets and put it into a CNC machine to do the edge cuts just like Gibson and PRS and every other manufacturer does. The only difference is that Fender doesn't bind their strat necks.
Couple of points: I own six or seven Gibsons at the moment. For many years I made my living selling (and playing) vintage and contemporary Gibsons in the past. I know Gibsons.
I'm not a "fan" of any maker or any gear. That suggests irrational acceptance based on some obscure emotional response. That's
stupid.
When I point out objective flaws on guitars, I not only know what I'm talking about, but I can clearly point out the flaws to a novice. When I do this, I usually get only a pouty "oh, you just don't like Gibsons (or whatever)," which under the circumstances is an inadequate response.
As far as your comment on neck binding costs, you're simply wrong. Doing a proper, traditional neck binding is inherently more difficult, expensive and less adaptable to automation than the butt-binding process Gibson uses. All makers have to hand-finish their fretboards and this system also requires less time to detail. As an aside, FMIC Fenders frequently have appalling fretboard detailing as well, as Fender is also attempting to cut US hand-labor time to the minimum. I have an "American" series Stratocaster with the frets detailed only on one side of the fretboard!
If Fender Corona did more top and neck binding, I wouldn't be surprised if it would be typically as bad as Gibson's, as - despite whatever level of CNT automation one can program - good binding & frets require expensive hand detailing, and American builders just won't pay the labor cost for that level of relatively skilled work.
[Most of Fender's bound instruments seem to come from Cor-Tek, a Korean company with skilled workers who work at a fraction of the costs of Corona's indifferent line-labor. The fingerboard and binding detailing on these instruments is typically
perfect. Likewise Fujigen Gakki Fenders.]
Gibson guitars are simply poorly detailed, whether they bear a $999 or $4500 MSRP. Again, read that FDP thread, linked above.
