Getting stereo synth parts into mono?
  • Thread starter Thread starter Alchemist3k
A
Alchemist3k
Hello, long time no post but I finally have time to get back into my recording again so hello to all those I've not seen in a while.
Anyhow, my problem is that I use a lot of soft synths and these almost always have only stereo output. Lots of stereo sounds in the mix are a real problem for me with sounds fighting for space.
Anyhow, I have found my mixes improve dramatically when I pan some of the stereo sounds however I only do this, not by taking true mono signals but by merely setting the pan of the signal I want less of to the other speaker so that it sounds less. e.g. normally a stereo signal has one panned hard left, the other hard right - e.g. if I want most of the sound on the left speaker I leave the left signal as it is but pan the right signal more towards the left. (I know, it's hard to explain but you know what I mean if you've ever used a computer recording system).This appears to have the same effect as if it was a mono signal.
What i want to know is am I doing the best thing? Would it be better to bounce the soft synth parts down to two separate mono signals? I tried this once before but with poor results, the synth sound didn't sound right when both signals were combined.
I make music a la Depeche Mode or NIN, so the idea is to have lots of little mono synth parts coming in, and liberal use of panning positions and panning effects.
Your method probably works okay.
The other obvious ways to deal with a stereo output that you don't want "in the middle" would be:
1 - Sum to mono and pan the mono where you want it. This is often not a good idea with synths, because some of them do some funny phase tricks to make the stereo sound "cool," at the expense of mono compatability.
2 - Just take one of the two stereo outputs and pan it where you want it.
3 - Take the two stereo outputs, and keep them panned hard left and right, but just adjust their relative volumes to get the result you want.
4 - Adjust the patch(es) with the synthesizer's own editing parameters.
The last two (3 and 4) are probably what I would most commonly do; sometimes number 2.
Your way is, if I understood it correctly, is similar to 3: take the two stereo outputs, pan one hard left (or right) and pan the other one wherever sounds right. In effect, this is sort of a hybride of 1 and 3. You're actually taking some of the right output and putting it in the left stereo channel (assuming one's panned hard left and the other is variable).
Yeah, that's what I do. To be honest so far it seems to have been quite effective.
I am realy not sure how to adjust my synths to give mono output, it's not very easy to do on the Dynamo anyway...
Stereo synth patches are usually just a mono sample with some chorus or delay so it is beneficial to just use a mono sample and add any stereo ambience during the mixdown.
I don't know how to program your softsynth but there is probably a way to do it in the patch editor.
