A
Alchemist3k
Hello, long time no post but I finally have time to get back into my recording again so hello to all those I've not seen in a while.
Anyhow, my problem is that I use a lot of soft synths and these almost always have only stereo output. Lots of stereo sounds in the mix are a real problem for me with sounds fighting for space.
Anyhow, I have found my mixes improve dramatically when I pan some of the stereo sounds however I only do this, not by taking true mono signals but by merely setting the pan of the signal I want less of to the other speaker so that it sounds less. e.g. normally a stereo signal has one panned hard left, the other hard right - e.g. if I want most of the sound on the left speaker I leave the left signal as it is but pan the right signal more towards the left. (I know, it's hard to explain but you know what I mean if you've ever used a computer recording system).This appears to have the same effect as if it was a mono signal.
What i want to know is am I doing the best thing? Would it be better to bounce the soft synth parts down to two separate mono signals? I tried this once before but with poor results, the synth sound didn't sound right when both signals were combined.
I make music a la Depeche Mode or NIN, so the idea is to have lots of little mono synth parts coming in, and liberal use of panning positions and panning effects.
