C
Chris Jahn
I personally like my mixes very hot, with kicking kick, huge toms, sharp guitars etc...
I often have a problem when i listen to my mixes on things other than my monitors (i use a mid range set of powered krk rockets so im using "real" monitors) the things i like to hear loud in the mix, are often to loud when i listen to them on cds' or in the car etc...
for instance, the toms are usually way to "boomy" the bass dominates the mix, the kick is a little to "hot" etc.... this all sounds fine when im listen to the "raw" mix straight from logic on my monitors, and is still pretty ok when i reference on lesser home speakers (still straight from the DAW).
I have tons of experince on the other end of recording, and always new that most issues with the mix were non existant once mastered. i.e. the engineer would always give us quick referance cds at the end of the night with the warning that "its not gonna sound right untill mastered" which was true, once mastered there was a world of difference (of course)
This brings me to my real question after that long winded nonsence. If im using good monitors and a good program and i like my mix the way it sounds straight off the boards (if you will) then how much can i count on that mix staying true to itself after i have it mastered. Ive yet to have anything ive done professionally mastered and im scared of the resualts. If im happy with the sound as is, will i be happy with it post mastering, and what are things you want to avoid or make sure of in a raw mix so that mastering goes well?
Sorry that was so long
