dobro
Sure, you're talking about how accurate Cool's splitter is, and I've been wondering about that myself. I mean, the thing I don't like about highpass filters is that they're *approximate*.
But what you're ignoring here is this: the splitter produces eight tracks out of one track. And then you can delete one or more of those tracks and make a mixdown of what's left, completely eliminating everything south of the lowest note in the mix.
You say you could do the same with a steep highpass filter. Well, how steep? I put a Q of 1.6 on the track I was working on, and there was still loads of stuff going on below the cutoff point. But using the splitter and then dumping the range below the cutoff point, there's NOTHING going on below the cutoff point.
Look, try it yourself. Before using the splitter and dumping the range you don't want, the track's got bottom end you don't want, EVEN IF YOU'VE USED A HIGHPASS FILTER. After using the splitter and dumping the range you don't want, the track's empty of all that range.
In the first case, there are traces of what you don't want in the bottom of the barrel. In the second case, the bottom of the barrel is scrupulously empty of what you don't want. Make your choice.
Just generate a profile for a 440hz sine wave in the noise reduction filter section and apply it. The precision of each of the filters differ because the programmers pick a common slope, cutoff, Q or any other parameter they deem as being the end to their means.
