sweetbeats
Reel deep thoughts...
I have an opportunity to purchase a VGC TimeLine Micro Lynx synchronizer system. The seller is a very trustworthy source. Unbeknownst to either of us the PSU is hosed. The system was a backup system that he purchased a couple years ago and never powered it up.
The Micro Lynx feeds on a three rail PSU, +12, -12 and +5.
The interconnect is via 5-pin DIN plug (like on the old pre PS2 computer keyboards).
I have tested the two ground pins on the stock supply connector and they are common to each other so I know the stock PSU doesn't have isolated grounds for the +5 and the +/-12V rails which, in my mind, is good (more better simpler).
Here we come to the crux: I have sitting here in front of me a standard 250W ATX computer power supply that has almost no hours on it. It supplies +/-12, +/-5 and +3.3V rails. I am assuming it provides relatively clean power considering its intended application though I'm going to scope the rails tonight to have a look. I have tested it and all of its grounds are common as well. Good. My only concern is that the -12V rail is running at just over -11V. The +12V and +5V rails look excellent in terms of the voltage they are supplying. Do I need to be concerned about the -12V rail running low? I realize that question depends on many things about the Micro Lynx, but in a general sense does it sound like a bad idea?
Anything else that sounds like a bad idea to doing this?
I have an old keyboard from which to pirate the DIN plug and umbilical lead and barring any red flags anybody can provide, this might be a really nice economical and quick solution to the issue that comes in a neat fan-cooled steel housing not much bigger than the stock unit...
, so I'm concerned that if there is a failure in the DUT the PSU is going to keep pumping up to a current that will take out a whole lot more of the DUT than would be the case when using the stock supply...the franken supply is indeed fused on the input side but I'm assuming that the fuse rating is matched for the max current ratings of the supply which, again, are much higher than the stock PSU.
...accidentally shoved one of the temporary wires into the wrong socket and *pop* the PSU shut off instantaneously to no apparent harm of the DUT.
