Fostex G24 24 track recorder Help?
  • Thread starter Thread starter glenn taylor
For anyone reading this post in 2015, I took a punt on a Fostex G24S on UK Ebay......a Buy It Now price of £350. I knew about the 'S' problem with the cards and figured I'd have a go at re-capping them. When the machine arrived, I quickly gave up that idea. My soldering is ok, but the caps concerned (about 33 on each board) are tiny....no really tiny. I knew if I attempted it, I'd ruin a board. As it is, I was contacted by someone who runs a studio and is also a tech who has a G24S machine which he re-capped himself. Well, a few weeks later and £800 later, I have a machine which is almost there. There was more damage to my cards than to his machine (when the caps leak, they of course leak electrolyte over the boards). He sorted most things out, I just have one card that doesn't meter at the moment, and another where the switching is erratic. I'm just going to run the machine a little more to make sure these are the only cards that need sorting, but the machine sure does sound nice, even though it's not properly setup yet.
Now this might seem like a lot of money to invest in a machine....I reckon you're right, but the tape is still available at a reasonable price and I also scored a brand new head for the machine, which means I may have a tape solution that will see another 10-20 years depending on usage. Given that the original cost of the machine was probably around £6-7000 in 1990's money, I reckon it might be worth it. Besides, whoever said this recording malarkey was going to be cheap.
Al
Damn...that's the first success story I've ever heard of anyone repairing bad Dolby S chips.
I'm just curious/confused...you're talking about the caps...but I always understood that actual S-chips shit the bed and then cause the problem. It maybe one and the same in the end...that the caps affect the chips...etc.
Anyway...does this guy have a microscopic soldering kit? :p
That's some serious recap work. :thumbs up:
That said...you are right, I wouldn't have spent that kind of money to refurb a G24... :D ...but whatever makes you happy.
After going to the 2" format...I don't miss small-format recording.
With the dead card, maybe move it to channel 1 (edge track, more damage prone) or channel 23 if you're using timecode (guard band to avoid timecode leakage).
Glad you've got it working nicely!
Interesting recap (no pun intended) of your travels with your new-to-you G24S, Al.
I also was under the impression it was the Dolby IC's that went bad.
Have any pics of the cards you can put up? I get sickly fascinated about just how hard a job it would be for me to recap something like that...wondering what they look like.
Thanks for confirming that...I mean, we both thought/heard the same thing...though of course, it may turn out that it is just the caps on the cards...
...which I still couldn't fathom wanting to or attempting to replace, considering the size and delicate/crammed in nature of those G-series cards.
Yeah...and what I'm going off of from memory isn't isolated to Fostex PCB assemblies with Dolby S chips...Tascam too, and whomever was blogging had isolated the issue to the ICs and each time it was a brick wall because the ICs were/are unobtanium.
If it is just caps that's tremendous, but I'd think that would have been ruled out before calling the question on the Dolby chips. But I have no first hand experience...just regurgitating what I've read on the "interweb ", so YMMV etc.
Well, it may be an expensive 'experiment'....only time will tell I suppose, but the guy that did the work does seem to know what he's talking about (and he does have a machine himself which he primarily uses to x-fer stuff from 1" to digital for clients). Of one of the cards (CH10) he did say this (you may be better reading from the bottom of this posting as I've copied his remarks with the most recent first):
Recording tests passed! Just waiting for the final few capacitors (promised tomorrow) to get the replay bass response to spec and they'll be ready to come back.
I've had the cards on soak-test for 3 hours today, so I'm as confident as I can be that I've cleared all the intermittent issues. I've calibrated the meters and input record level at TP3 as per the service manual, but beyond that it's over to you to calibrate to your head and bias to the tape you choose to use.
One issue that I can't fix: I'm suspicious about the Dolby circuit on channel 10. With NR 'off' the channel plays as expected, but there are some unexpected dips in the frequency response with it 'on'. There are two sealed calibration pots for the Dolby circuit which require specialised test gear to set up, but I suspect it's the module that will need replacing - not a part I have access to. You'll need to contact Fostex for advice, or possibly find a spare card somewhere.
As you may have gathered it has been an absolute nightmare to trace all the intermittent issues - I'll enclose a full service report with the boards. I can only think I must have been incredibly lucky with the machine I bought - no further faults at all after the electrolytic caps were replaced.
I suggested swapping CH10 over to CH24 as I will be using timecode which doesn't need Dolby
Yes, swapping cards 10 and 24 would seem to be a perfect solution.
The problems are 99% down to Fostex using substandard electrolytic capacitors - it's a known problem with these machines. Think of cheap unbranded batteries that leak as opposed to Duracells that don't. Now they've been replaced you should have no similar issues, not for many, many years anyway. You'll see that the replacements are three times the size of the originals: these are quality components, chosen for maximum reliability and performance. The boards don't look so neat, but you'll get the best possible life out of them. The circuit is not power-hungry and the cards don't generate much heat, so no cooling required.…
Hmmm… Sorry about that - very annoying - I calibrated the meter drives and they were all working fine here. Odd that it isn't reading full scale: if the op-amp chip fails you'd normally get full output voltage or zero volts. The meter drive design is a little unorthodox to say the least and very sensitive to leakage current, so perhaps there's some electrolyte left that I didn't manage to clean off.
One little test, if possible please. Can you input an audio signal that is enough to just read full scale when input monitoring on a working channel, then apply this same signal to the rogue card input and see if more LEDs light. If so, then leakage is to blame, and a gentle clean with isopropyl alcohol and a soft toothbrush around U5, D8, R68 and R69 and C42 - on the square inch or so just above the larger edge connector - may do the trick. Dry off the board with cotton buds and rinse and dry a second time with a drop more alcohol. If not, it could indeed be that it's another chip gone south or another diode breakdown.…
I'd agree with you there - something odd on the card. However, it's the bit about the meter reading signal only when the output lead is plugged in that makes absolutely no sense - it suggests that signal is being introduced along the cable somehow. For example if you take the input lead carrying the 1kHz tone and accidently plug into the output you will get a meter reading if the signal level is high enough…
I can't think of anything else so I suggest replacing the meter drive op-amp and cleaning the contacts underneath is probably the best way forward. By all means post the card back to me and I'll look at it as soon as it arrives. Sods law will, of course, mean it will work perfecly in my machine, but I'm happy to replace a few parts on the off-chance if the fault doesn't show itself. The joy of intermittent faults!
Your board is on the way back.
True to form, it initially worked, but fairly quickly the meter started reading without any input. It turns out the output buffer op-amp was unstable and oscillating at around 270 kHz. This is a problem with most op-amps and highly capacitive loads, hence the output cable triggering it, but there are components in the circuit to maintain stability which should cope with anything other than impractically long cables. I suspect good old electrolyte leakage was to blame. I've lifted and cleaned all the associated components and replaced the op-amp IC, and normal service has been resumed.…
Oh, ***k! Very sorry you're having further issues. I'm beginning to wonder if these output op-amps have all been stressed somehow by something like a power surge in the past - there's no reason why they should fail now. The lack of input/output could also indicate failure of the 5V regulator, and these certainly could have been stressed by the leaky capacitors, or a power surge. I replaced 3 if I recall. Can you double-check the +24V, +15V and +12V power rails, please.
Yes, I think some serious soak-testing is called for - the 3 or 4 hours I had the machine running for would seem to be insufficient, though I repeat, there's no good reason for such components to fail now the leaky caps are gone. Having replaced all the electrolytics in my machine (and nothing else!) it's worked flawlessly ever since.…
'There is a 'logic' connection to each audio card, so it's possible that a bit of bad data in memory was causing switching issues, particularly if the memory battery is either failing or insufficiently charged. If audio is at the output but the meter isn't reading though it does point to the op-amp IC. Please take a look at card 21 and see if the 8-pin chip next to the group of 4-pins of the Dolby sub module has been replaced. Also check the 5V rail on this card if possible - yes, remove the 4 of 5 boards next to it to gain access.
Well, at last there is daylight appearing at the end of the tunnel that has been this week! It's been frustrating as I've had to clear faults in sequence, which has meant ordering components in different batches as required.
Having cleared the failed op-amps, most of the issues I've encountered have been due to contamination of high-impedance stages of the circuit. For example, the switching FETs have floating gates when 'On' which have proved to be incredibly sensitive - breathe on the board and they switch 'Off'! It seems the combination of inadequate cleaning of flux at the factory, coupled with electrolyte leakage and possibly a hint of nicotine has been a very bad combination. Fortunately a years supply of cotton buds and swabbing alcohol has got them switching reliably.
I've had to replace two 5V regulators that had failed, but fortunately no further damage to the logic circuits they power had been sustained.
The playback amp also has a high-impedance path, and I'm currently waiting for some more capacitors (responsible for the correct replay EQ) which have absorbed electrolyte, causing loss of bass frequencies and increased distortion. This, with everything firmly crossed, SHOULD be the final step!
These caps should be here on Tuesday, and I'll be able to fit and final test then. There is evidence that pots have been twiddled with, so I'll calibrate the meters and replay EQ, which will be a good starting point for final tweaks to match your replay head.
An op-amp (operational amplifier) is an integrated circuit (a silicon chip) - like a transistor but with 8 legs, in this case. They're more awkward to deal with than capacitors because of the more complicated soldering. Semiconductors are the active elements in circuits and hence the most prone to failure - resistors almost never fail in low-power circuits like these.
So far I've found about 10 of the same device in the same circuit location which have failed on one half or the other (each 'chip' contains two amplifiers). They're not expensive - around £1 each - so it's crazy not to replace as needed. These failures account for such issues as no audio output, dead meter or full scale meter reading, depending on how the device has failed. I need to replace these first before I can check the earlier stages are working correctly.
All in a day's work!
(In response to finding a fair few op-amps failed he asked me to test three voltages on my machine, which reported in spec)
'Good. It's worthwhile proceeding with the opamp replacements then.
I'm not worried about the meter readings with the cards removed; the way the meters are driven in a bit of a fudge to be honest - hardly a precision circuit design, and there seems to be a fair bit of 'OK, that'll do' attitude evident!
With so may semiconductor failures powering is the first thing to suspect, hence the need for the test. It could be that a previous owner was removing/replacing boards with the machine powered up - guaranteed to kill something.
I'll plod on…
Hi Alan,
I've found a fair number of blown op-amp chips so far, mostly the line output/meter drive ones, but there are some other odd faults I've yet to trace. It seems like a lot to go wrong, and far more that I'd expect from leakage issues. I'm beginning to suspect that the machine has had a power surge at some point. Can you access a decent quality multimeter and verify that the power supply +24V, +15V and +12V rails that feed the audio cards are all within a fraction of a volt, please? I'd expect the tolerance to be + or - 0.2V on all rails.
I've attached a PDF of the power supply circuit and connector board: the voltages are on connectors J2 and J3 on the regulator board, destined for the main connector board which the audio cards plug into, or, possibly easier, on J7 4 on the connector board itself.
I had to re-order the chips as they sent the wrong package - too small even for these boards, would you believe!
Sorry about the slow progress.
Just a quick update. I've completed the cap replacement and have the boards installed in my machine for testing. Unfortunately five of the boards have op-amps that have failed, most likely because of the leakage currents. I have ordered replacements and will fit as soon as they arrive.
It does seem rather strange that the affected boards are 4, 8, 12, and 16 - a bit of a sequence - plus one odd board, 17. Looking at the circuit diagram it seems unlikely that a failure elsewhere could have caused these chips to get fried, so to speak, but it is an odd coincidence. Can you please power up your machine briefly without the audio boards, and see if there are any residual meter readings.
OK, that's somewhat encouraging - I've seen much worse! You're right - the erroneous meter readings show that the capacitors are leaking badly (electrical current, as opposed to physical electrolyte, though that's the next stage). The only way to get a reliable machine that performs to spec is to replace the lot, as they will all be of a similar age and state of decay and will only get worse. We're talking about the rectangular plastic cased electrolytics with both terminals at one end(e.g. C21, C22, C27, C28 etc.), not the ceramic 'axial' types or conventional through-hole types.
In theory, assuming the preset pots haven't been twiddled in an attempt to equalise the meter readings, the boards should just slot back into place after cap replacement and you'll be in business: there should be no need to ship the whole machine.
Assuming all boards are as clean as the photos and you send me just the boards, to replace all surface mount electrolytics with top-quality Panasonic audio ECA, long-life low impedance EE series and polyester film as appropriate, time taken between 1.5 and 2 hours per board, plus components at cost:
One caveat with these machines, though. It's most likely that you'll be using a different type of tape to that which it was calibrated for in the factory (Ampex 456, to the best of my knowledge, now no longer made, and most of the old-stock will be 'sticky' - avoid!) This re-biasing is an absolute pain on single-head machines, since you can only do it incrementally and not in real time: record a tone, play it back, adjust a bit, record another tone, play it back, adjust a bit more, and so on. Repeat for each channel… I assume you have the necessary test gear to do this.
You'd be wise to purchase a reference tape to correctly calibrate the playback response before attempting to adjust the record side. Canford should still have them: 320nWb, 15ips, IEC-1 is the type you need.
Out of curiosity: are you intending to record new material on this machine or is it purely for transferring archive tapes? Frankly, there are more economic stand-alone digital recorders available - the Alesis HD 24 being my favourite tape-machine replacement.
I do all work in-house. This was Fostex's first foray into surface mount and their chose of the miniature electrolytics was a very bad one - they all end up leaking (both current and electrolyte.) Best solution is to replace all (30+ per channel) with full size non-surface mount - I use special audio-grade caps. There is enough room between the boards to accommodate these components, you just have to be a little more careful when sliding them in.
The biggest problem is where electrolyte has leaked onto the board - the tracks are very thin and I had to get into some serious cleaning before the new components could be fitted, even repairing a few tracks.
Please extract a couple of boards (remember which channels they are) and send me a couple of close-up pics to assess the damage.
You can find pics of the machine and boards at Flikr
https://www.flickr.com/photos/33383402@N06/albums/72157658219628751/show
Sorry about the length of the post, but someone who is struggling with a repair might find something in it to help them. It was certainly well beyond my limited electronics knowledge to sort out.
Al
Thinking about all the problems that the tech found with my boards, it's probably safe to assume that if some electrolyte did find it's way to the esoteric Dolby chips, then if it ruined these chips and they are unobtanium (nice word Cory) then possibly every future problem with the G series cards is then put down to 'the S chip' problem , when in fact it could be a myriad of other problems.....I'm just guessing here, but my boards had several intermittent problems that only a tech probably could work out. I'm running the machine at the moment to see if there are any more problems, but at the moment there are only two cards that have minor problems and will have to go back.
Al
Read through all that, Al. Better him than me for recapping those cards. :cursing:
Surface mount components on a double-sided PCB. At least they are glass fiber and not phenolic boards.
So after reading through all that it doesn't sound as though you have widespread known issues with your noise reduction, but also he was not addressing N/R issues. The recap was not related to N/R. So, in my opinion, you still have that hanging over you at some point. His repairs addressed faulty electrolytics that caused (in his estimation) failure of other active components (opamps, not N/R related).
Is that what others are seeing?
I think that's a fair assumption Cory. BTW, the boards are about 6-8" square, so it gives you an idea of how small they are. What I meant in my previous post was that once electrolyte leaks from these caps (the flat, rectangular ones) who knows what damage they do to the other components? I suppose long term, if the machine still works with the Dolby disengaged (a global switch on the rear selects 'ON' / 'CH24 OFF' / 'OFF') then the option would be to run with it off or invest in an external Noise Reduction solution....would that work? Something like the Tascam MS-16 external DBX units or similar...or am I barking up a totally wrong tree?
Al
If you do a search about these boards Cory, then there are about two or three techs online (Funky Junk in London I think were one) that seemed to come to the same conclusion....that all these flat caps have to go, because it's just a matter of time before they leak.
Biggest recapping ever
Fostex G16s G24s rec/repro card recapping
Re-Capping a Fostex G24s Reel-to-reel tape deck - Audio Restored
https://www.youtube.com/watch?v=rtvOJlI15H8
Only time will tell I guess.
I will add that my machine has the synchroniser board fitted which after having Tascam Midiizers to sync stuff up is a bit of a revelation. The Synchroniser board will generate its own LTC. It will then convert this to output MTC (rather annoyingly though, it won't save this as a default setting, so everytime you turn the machine on, you have to feed it midi notes 78 & 61, played together.......really weird) and if you had another tape machine, it will take the LTC from that machine and sync to it....very clever stuff.
Also tonight, I finally got everything rigged up to one of my recent Ebay desk buys....a Mackie 8 bus console. I don't think I'll be keeping this though, as I have a few Soundcraft Ghosts that I want to try with the G24S. I will however be keeping the Mackie Ultramix package that I've finally got sorted via a laptop running Win XP with an M-Audio Midisport 8x8. I've just done a test session tracking to the G24S...then dumping stuff to the Fostex D2424LV (digital), all synced via MTC courtesy of the G24S synchroniser card.. I then automated the mix using the D2424LV as the sound source and the Ultramix software. Finally when the mix was how I wanted it, I patched 24 patch cords into the normalised patchbay and the G24S comes back on line for a final run through, with the Ultramix replaying the mix. The sync for the Ultramix software was now coming from the G24S. It sounds complicated when you write it, but it isn't once you actually run it.
It was really interesting doing a mix like this, because one thing I immediately noticed when I fired the tape machine back up for the final pass was how much more 'exciting' the sound was compared to the D2424LV. I suspect it has something to do with the inconsistencies of tape, possibly the way we hear volume......either way it just sounded more pleasing and less exact /sterile......This way of working offers:
1. I can track new parts on tape if I want and have them sync to the D2424LV as a means of a backup (albeit digital).
2. I can spare the tape machines heads and mechanism the repeated playback while perfecting the mix
3. Using Ultramix, the benefit of using an analogue mixer isn't accompanied by a rise in noise, and although it isn't flying faders or eq / dynamics recall, it does offer some way to reproduce a mix. I am thinking also of designating certain tracks always to the same part (that way the vocals always have the right eq etc).
4. I might be able to offer clients the chance to track on tape, and either buy the tape or have an export of WAVs. I don't run a studio, but small jobs might come from the use of a totally analogue sound path.
Al
Al,
If I'm seeing it right on the boards the Dolby "stuff" is on a surface-mounted daughter board that is separate from the main board. The electrolyte from the leaky caps wouldn't contact the N/R sub-assembly. The electrolyte is (obviously) conductive so you've got two potential problems when it leaks out: current leaks to wherever the electrolyte physically leaks on the board which could cause component failure, and caps that no longer function as they should (either filtering or blocking or coupling) which could lead to component failure. So maybe one or both of those could cause trouble for the N/R sub-assembly components but I wouldn't know unless I could cross-reference the failed caps with a schematic. If the assembly works, it works. The dreaded S-chip failure is NOT, as a phenomenon, related to failure of electrolytic caps in my understanding; it is an innate failure of the proprietary Dolby S IC. I think you have two assemblies that are in failure state. I would wager this is not related to the leaky caps. I suspect over time there will be more to follow. If it was me I'd be seeking an external dbx Type I solution. The Tascam DX-8DS Type I N/R units found on the MS-16 are not really an ideal solution because their power comes from the supply inside the MS-16, and their switching and interfacing are via unobtanium Hirose Sumicon 1600 series connectors, and some of the functionaility is external as well...quite a project to interface with a non-MS-16 machine. Best solution would be to find six DX-4D units and modify them to function without the "control" cable, or get 12 dbx 150X units. I happen to have 4 of them for sale. :D But I think those are pretty much your options.
I hear you Cory...I wonder BTW where all those defunct Fostex G24S machines end up? As a keen follower of Ebay over the last fifteen years or so I've seen maybe a handful of machines make their way to the Ebay graveyard. If a machine pops up with the Dolby C cards I may jump on it (Miro, are the cards totally interchangeable?). As far as the two cards I still have problems with are concerned I'm sure the problems are non-Dolby related....one has intermittent switching issues (sometimes records, sometimes doesn't, sometimes plays back, sometimes doesn't.....whatever switches isn't working right....and the other card doesn't meter but does record and playback fine...). As with all things, economics plays a part. I'm thinking of setting the machine up to use Quantegy 406 as there is a dealer quite local that has NOS which I've had and it is in perfect condition, no shedding etc. The tech I've used suggests that I won't get the full benefit of the machine without using RMG or similar but it costs three times what I pay for the 406. That's one of the reasons why I've never dipped my toe back in the 2" game......unless you've got access to decent tape at an affordable price, you've got a washing machine that can't record audio.....never mind the increased service costs.
I'm not going to plan too deeply for the future. I still have a Tascam MSR16 which has been renovated for sale...I'll hang on to it until it gets what I want for it. I picked up a mint condition 688 that again I'll hang onto unless I get a decent price for it. The G24S does have its quirks. The synchroniser board seems to have been designed with 'computers' and midi in mind....lots of the facilities only seem to be operable through midi messages rather than front panel controls (it's really weird pressing C4 on a keyboard and seeing the machine start playing......then pressing C5 and seeing it stop....I'm too old for that). Having said that, this setup at the moment seems the simplest in terms of my search for a 'poor man's CLASP' that I started with the Tascam gear about 18 months ago. The D2424LV use of IDE drives (albeit once again, quirky, I think limited to Western Digital drives) means a 160Gb drive can contain all the stuff I've recorded from the last fifteen years. This means I can access old and new stuff equally easily. All systems have their own strengths and weaknesses. Only by using them do you find out whether they're a ball-breaker or just a bug-bear.
Al
I wonder what a G24S would sound like with this Dolby SR24:
Al
If you do go the DX4D route, I have 8 channels sitting doing nothing. (I must add they are untested.) Basically, I was about to buy a Tascam 38 all those years ago, but ended up with a TSR-8 instead. I have this weird horror of selling things on ebay so they're just sitting on top of a cupboard.
EDIT: As for the synchronizer, I have a similar situation with the Aeolus synthesizer which I've recently set up running standalone on a Raspberry Pi. It requires a particular set of MIDI operations to initialise it. If you need a device that simply powers on and sends a couple of MIDI commands I might be able to help you rig something up. Obviously you'd need a Raspberry Pi and a compatible MIDI interface and arguably even a Pi is overkill but it's a possibility.
I remember reading this years ago at 'Tascam Forums' site and include it here as a point of reference:
Originally by Tascamwiz:
'I have worked on various brands of analog tape machines since the 80's.....Studer, MCI, Ampex, Tascam, Fostex, etc, as both a technician and recording engineer. I sold my last Ampex ATR in the mid 90's and have been all digital since......well......in the past few years a lot of my associates have been digging up analog machines in various states of neglect and dis-repair and bringing them to me to resurrect (as if I have nothing better to do).
I'm not sure if anyone has gone into this recently, but, I have noticed among the narrow format machines that almost every single Fostex G-series, Tascam MSR, TSR, 238, etc.... I have worked on that had Dolby-S noise reduction has had problems with the Dolby-S chips. I have seen them burned, shorted, and open. Some machines have 1 or 2 dead NR channels, some are nearly all dead. It appears to me that these NR chips are very sensitive to both drifting circuit tolerances and power supply voltage tolerances. I have seen these issues on several different brands of reel-to-reel and cassette recorders, so I do not think it is related to poor product design. These chips have not been made for several years and are not available as individual replacement parts when they do fail.
After talking with some colleagues, I discovered that the probable reason for these issues is that due to cost constraints the original Dolby-S circuit design (simplified and derived from Dolby-SR) had to be condensed down to a single asic in order to meet integration cost targets with the various manufacturers of consumer audio tape products in the early 90's. Large scale integrated circuits were still fairly new in the late 80's/early 90's and the Dolby-S asic chips were made using a new (for 1991) fab process known to have problems. It is called the bipolar master slice (M/S) process. This fab method had several "advantages" over a typical custom IC design, including lower cost, fast turn around time, more design flexibility, and supposed quick assessment and correction of design problems. The advantages of the new M/S fab method were key to the design of the S-type IC due to lower cost requirements. This is because circuit design changes to accommodate integration and performance requirements, and testing and evaluation was difficult. The resulting IC was a low-cost, single package device that was readily accepted by manufacturers for low cost and easy integration into analog products as digital products became more and more mainstream.
It is possible that these problems may have been resolved later on, but, since the majority of Tascam and Fostex machines that were equipped with Dolby-S were made in the early 90's, it is fairly certain that Dolby-S problems with these machines will be fairly common as these machines get older.
Aside from technical problems with Dolby-S, I see machines advertised all the time as having the "desirable" Dolby-S NR vs the "undesirable" DBX NR. To me this is/was pure marketing BS and is something I do not understand because Dolby-S NR IS NOT the same thing as Dolby-SR in terms of capability, complexity, and quality. Dolby-S is/was a simplified, cut down, and cheaper version of SR developed primarily for the limited audio bandwidth and simplicity of cassette recorders. Any cassette deck manufacturer that wanted to incorporate Dolby-S into a product was required by license to include an automatic calibration routine as far as setting record bias/eq/level for a particular tape was concerned. This is because Dolby-S is extremely sensitive to mistracking due to level and frequency calibration problems typically as a result of incorrect bias/eq/level settings. The fact that it was adapted to be used on machines that record in a studio is mainly in my opinion because Fostex used Dolby because Tascam used DBX, and, Tascam later used Dolby because Fostex used Dolby......marketing and sales, nothing more.
If calibrated correctly by a skilled tech, Dolby-S gives at most 3db of NR improvement over Dolby-C with a bit of low frequency NR as well and good sound quality.......as long as the tape and calibration does not change!!!
Most narrow format Dolby-S reel machines have dozens of circuit cards and adjustment settings that must be maintained on a regular basis in order to maintain decent fidelity and correct NR tracking. Pro reel machines obviously no not have an "auto-calibration" button like some cassette decks do, so Dolby-S NR mistracking is quite common. Aside from the ASIC problems with the Dolby-S chip itself, every single Dolby-S machine I have worked on had at least several channels in which the calibration was way off and with subsequent poor sound quality with the NR switched in.
DBX NR on the other hand is a relatively simple 2:1 linear companding NR system that allows for a lot more signal on tape before saturation, 120db of dynamic range, and 95+db s/n ratio. I have heard of all the reports of DBX "breathing" and "pumping" and other audible artifacts. The Tascam MSR generation of tape machines has in my opinion the best integration of DBX of any analog tape device ever made. As long as the tape machine is designed to have flat frequency response, DBX NR can provide amazing sound quality and low noise with zero artifacts, and, since it is not level sensitive, will tolerate a fair amount of mis-calibration before audible artifacts occur.
I have 2 MSR-24's on my bench right now, each with freshly lapped heads, a complete tune-up and aligned to RMGI 911 tape. One has Dolby-S, the other is DBX. I recorded a couple songs from a Mobile Fidelity SACD of Patricia Barber's "Cafe Blue" to tracks 8 & 17 (stereo L&R) on both of them and fed the outputs through a Sonic Frontiers preamp and a pair of Balanced Audio Technology VK-150SE monoblock tube amplifiers driving a pair of Magnepan MG20.1 planar loudspeakers......about $25,000 worth of playback equipment not including the Tascam units. I then did an AB comparison between the SACD player and the MSR-24 with Dolby-S and between the SACD player and the MSR-24 with DBX for 5 different people. They could better than 8 out of 10 tell the Dolby-S MSR-24 copy from the SACD source. On the DBX MSR-24 it fell to about 50/50 which is statistically significant in that they could not tell and were guessing.
So.........my 2 cents worth is if you are looking for a narrow format tape machine, the Tascam TSR-8 and MSR-24 with DBX are hands down the best you can get in terms of sound quality and reliability......the MSR-16 might be good to, but, its track width is really getting down there. I would not pay extra for Dolby-S especially given the problems with the ic's.'
Hi JP,
Thanks for the offer, but it's not too much trouble to press a few keys to get the G24S to go into MTC emit mode. It just strikes me as peculiar as to not offer to store that setting once you've done it....the machine can store a multitude of other stuff which it retains on power down.....a default setting like this seems really remiss. I have all the MTC hook-ups done via the M-Audio Midisport 8x8 (8ins / 8outs) which features INP8 and OUT8 on the front panel, so I might just leave a small keyboard on top of the rack to deal with this. I could also setup a 'Reaper' project to spit out the relevant notes as the laptop will be on most times. It only needs doing on power on, and since the G24S's capstan only spins when the tape is actually moving, I don't mind leaving the machine in 'take-up' mode for long periods, unlike the Tascam MSR machines.
Al
As soon as I got my 2"...I went all out looking for tape. At this point, I've got such a huge pile that I can record for a long, long time. In the last two years I scored on multiple NOS deals at great prices...like $200 for 4 reels of 2" BASF 911 just recently...and back in the spring I scored 7 reels of NOS 499...not to mention a large pile of used, but quite good reels.
I was concerned at first when I got the 2", that tape would be expensive or hard to find deals...but I check daily...and it might take 6 months to see a deal come up, and then I grab it to add to my stock.
AFA service...knock on wood...I've not spent a penny on servicing the MX-80 since I bought it. THe guy before me did all that. :)
I did have a spare remote serviced, so now have two...and that cost me a few bucks (about $600 + $200 I bought it for)...but that's my insurance policy. Also, I got a ton of parts from the guy when I bought it...and I've picked up spare motors, heads, cards, etc,
So I'm not worried about the service at this point. I also have a top Otari tech on tap. He's the one that did the remote, and also the one that serviced the deck when the other guy had it.
Right now....again, knock on wood...it runs smooth as silk, like new, and sounds as good...which is why I said earlier I wouldn't want to go back to small-format recording.
... it's not too much trouble to press a few keys to get the G24S to go into MTC emit mode. It just strikes me as peculiar as to not offer to store that setting once you've done it....the machine can store a multitude of other stuff which it retains on power down.....a default setting like this seems really remiss.
I use to the the same thing. I had a MIDI sequence that I would simply play back to the G16 to get it to set.
That said...
There is a battery on the back-panel PCB...a rather large lithium battery that you can't miss when you open the back.
That is what maintains a lot of the user settings. Some of the default stuff is probably coded into an EPROM.
I've changed the battery on my G16 once...and I have a spare. It's an odd battery (if you want the specs I can find them)...and I got a substitute that fit right in, as I don't think Fostex stocks them any more....and hasn't for ages.
Oh...on the cards....if you are asking if you can remove the S cards and replace with C cards....mmmmm....not 100% sure.
I would certainly want to do it with all the cards, not half & half....but there may(?) be some other global setting/circuit that ties into them being S cards on one of the other control PCBs.
So I think that's a trial-n-error thing...if you can get some C cards...try it out.
To tell the truth...I'm sitting on two G16 Dolby C decks. One is my original, and the other is a used one I picked up as a spare (right before I bought the 2" Otari MX-80 :facepalm:). It has a lot more wear than mine, but functional. I was holding on to it in case...........?
I've been considering selling both decks and a bunch of spare NOS parts I got from Fostex when they still had them.
My Otari MX-80 is running great, and even if it went down, and needed service, I wouldn't bother going back to the G16 in the interim...and worst case, if the MX-80 was run over by a train while doing a remote field recording session, and it was completely demolished :D ;) I would look for a replacement, or...dare I say it...consider going to DAW recording SOP :eek: and I can still mix OTB from the DAW.
Anyway...I'm just not motivated at this moment to pull the G16 out, get it all packed, etc....and do the sale thing.
It would leave a big hole in one of my gear racks that I would then have to fill with some other equipment. :p
No...like I said, I have the G16 with the original manual for the G16. I've never compared them page for page, but I would think the operation manuals would be about the same.
AFA the schematics...there would be some differences between the C and S.
