G
glenn taylor
Hey gents I just bought a Fostex E16 in very good condition except it won't rewind?
Anyone know about these machines? GT
No I can't turn it backwards while in rewind. GTcan you manually turn the tape backwards once you've hit rewind?
If so, could be a blown fuse, bad motor, and if not the brake could be stuck on.
Can you hear the motor running when you press rewind? or absolutely nothing happens (no sounds)?
I'm not sure if the E16 uses pulley/belt drive rewind but my R8 didn't want to rewind either when I got it but it turned out the belt just fell off the pulley (easy fix).
