Fostex A-8 anyone??
  • Thread starter Thread starter TASCAM MAN
Hmm. I just got out the manual for the thing and I can find no mention of NR at all. I bought it brand new, when they came out. I am (was, hell don't know) postive it used Dolby C. I do remember that I had owned it for a couple months and something went wrong. My dealer sent it back to the factory service center. I was pretty sure I was told that something had gone wrong with the Dolby circuit and it was replaced. I do know that when I replay tapes recorded on the A2 back on my Otari MX5050, there is a good bit of hiss. But zero hiss on the A2. Go figure, I am sorry if I have given you bad info. Maybe someone that services Fostex machines will weigh in and give a definitive answer.
Just a thought, the Otari's have an adjustable operating level. I wonder if you haven't switch it to the same one as the Fostex? (Also, I'm not sure what the factory setting on the A series, I think it's 250. I'd have to check which that is on the Otari. Not sure if that is the culprit.
But anyways the 8TK has only one speed set at 15 IPS and the 2 TK beleive it or not is the one that has a choice of 7 1/2 or 15 IPS. I actually would like to see that reversed right??
Chances are, you can change the speed internally on the A8 - you certainly can on the larger E8.
James
Im sure the A-Series was one of there first machines :cool:
I've read it was the first 1/4" 8 track. They all (the A8/80/R8) look like they have pretty similar transports though. I don't know how different the electronics are.
Yeah, but the E8 is considerably more sophisticated technology. The A8 is pretty clunky from what I remember.
If Fostex are consistent, the A8 will share the transport design with the A2. If the A2 can do different speeds then I would be surprised if the A8 can't with the right mods.
Hmmm - just downloaded the service manual and it seems that the capstan motor already runs at 2 speeds - 7.5ips when idle and 15ips when in play or record - so in theory it would be simple to keep it running at 7.5 ips while in play or record.
James.
In the A8-LR supplement section of the A8 Manual, it says the A8-LR came in a low speed/7.5ips version and a high speed/15ips version. This would also indicate there may be a way to mod the speed feature. It might pay to carefully study the A2 or A4 schematics and look for differences between them and the A8/A8-LR. However, IMO 15ips is a good operating speed and 7.5ips is not an issue.
:spank::eek:;)
Belive me guys,the A-series are nice sounding and running little machines for the money I paid...they do not have to be "modded" for any reason being in the category of tape recorders that they are:eatpopcorn:
I don't own one, but doesn't the 388 run at 7.5? The only advantage I'd think is running time though.
Yes. Running time is longer, which I suppose is an advantage, but it also imparts a distinct sound that's different than 15 ips.
:spank::eek:;)
I dont know what a 388 is?? I started this thread specifically about the Fostex A-Series although I have 2 Fostex A-Series,both probably there first generation in semi-pro reel to reel recording. Both machines look identical (gray and orange with VU meters)but do NOT say A-8 or A-2 nowhere on the machines,they both just say "A-Series".The 8TK version is set at 15IPS I think (havent used the unit buy on one song) and has Dolby C built into it with an INT/EXT switch. The 2 TK version is 7 1/2 or 15 IPS switchable and plays back all of my TEAC 3300SX mixes flawlessly. When I bought these machines on e-bay yrs ago,I was only curious to see if they compared to Tascam recorders. They are a little more semi-pro than Tascam is all I can say,cause they sound pretty dam good for what little money I paid and for how long they sat up (around 5 yrs) and were never touched for that long.I thought i was ju,st "toying" around with them but I really beleive if I wanted to that I could build me a little studio around just them 2 machines and a nice little analog mixing board :eek: :laughings: :eatpopcorn:
T-man: the 388 is also known as the Tascam Studio 8. It is a 1/4" 8 track with a built in mixer. Like a cassette portastudio, except with 7" reels. It's big, heavy, and beautiful. You mentioned running the A-8 at 7.5ips which is why I brought it up. I imagine if time were not a factor, it would be worth the effort to explore the conversion idea. FWIW, I also have a Teac A-3300SX, and I posted in passing on Tapeheads about converting it into a 2-TR. As I'm sure you're aware but for the benefit of hte masses, the two track runs at 7.5 and 15 vs the 3.75 and 7.5 and is half track. Skywave (?) I forget his handle at the moment, said it really isn't that difficult and he had parts for it. At the moment I need a 1/4 track that will run at 3.75, so I haven't explored that further, but just an FYI.
Ok I remember that machine now, I actually was hired to go and do some mixing at a lil studio that owned one of them yrs. back....always thought it was a cool machine !!!:listeningmusic:
