For frequency analysis: SP-B3 (omni mode) or Nady CM-100 ?
  • Thread starter Thread starter aznwonderboy
A
aznwonderboy
I want to get a graph of frequency response from my room and monitors. CoolCat suggested using Nady CM100 reference mic. I did some searches and another similar mic is Behringer ECM8000 (which is suspected to be the same one as the Nady with a higher price tag.) Both mics are omnidirectional, which is the essential feature for referencing.
I have a Studio Projects B3 that can do omnidirection. Do you think I can use this, or should I go ahead and buy the Nady?
The smaller diaphragm omnis tend to have a much more flat frequency response, which is what you're looking for in a measurement mic. A large diaphragm in omni will not be nearly as accurate.
The Behringer ECM8000 also has a lot of real-world practical uses too, dunno about the Nady, but Harvey has discussed using the Behringer for drum overheads amongst other things.
Again, I don't know about the Nady, but self-noise might also be a factor to consider with the Behringer - it seems variable between mics. :)
Scrubs - Ballitude wasn't really supposed to be a real word you know! :o
Nik
Nik
Yeah, but if you google it, it appears to be catching on. :D
And I'll second the ECM8000. Used it last night on nylon string guitar and it sounded very nice (despite having not changed the strings on that guitar in over 2 years).
When you're measuring frequency response of speakers or a room, microphone self-noise is not a factor. You're not interested in the noise, only the frequency response. The ECM8000 or the Nady CM100 will both work fine.
I was thinking more in terms of getting some dual-purpose value for money out of the purcahse .. but yes, you're right of course! :)
The high self noise isn't a problem when you're recording loud stuff. I use the ECM8000's for tambourine, congas, guitar amps, flute, sax, acoustic guitars, and drum overheads - anywhere I want a really accurate picture of what's going on..
