BeniRose
I've been thinking a large part of my workflow that's slowed down is dialing in my EQs and Compressors on each channel. I was thinking of getting a behringer bcr2000 to use just for my plugins, but then I saw that the Focusrite Liquid Mix 16 was only 200 dollars. Putting aside the fact that I'm not sure if 16 channels is enough (I think you can add a card for either 8 or 24 more channels, I couldn't tell if the number it listed was total or additional) I'm not sure which route to go. I'm currently using Logic Pro 8 (soon to be 9) so setting up the BCR will be pretty easy, but I'm still pensive that I will still have to do lots of mousing to or zone changing in order to get it to work the way I want. The liquid mix entices me because it's an all in one solution. The effects it's controlling are directly on the box.
That being said, it's not a great visual interface. There's no feedback on the values you're set to, and there's only enough knobs for controlling 1 band at a time (not that I usually do more than one at a time anyways, but it's not a full tactile representation across the EQ). Not that these things are huge deals, I can just look at the screen while I'm controlling them, so I think it would still work fine, and it would probably be less hassle to set up, which is really the goal I have in mind, but I'm also curious about the sounds of the plugins. I'm currently just using the Logic EQ and Compressor, which I',m not the biggest fan of but it gets the job done. Will the stuff that comes with this be at least as good if not better? Or should I stick with the control surface?
