Hello all,
I wonder if anyone could help me?
I have a soundcraft spirit folio 12/2 and it has begun crackling consistently rendering it pretty useless.
I've narrowed the crackling down to channel 9/10 which is one of it's two stereo channels. This channel has become totally kaput - nothing coming through it but crackle and fuzz. When I pan left and right on this channel the crackle follows it through the main channel.
The mixer has a PFL button on each channel which allows you to monitor the signal pre-fader. With this pressed on channel 9/10, the channel works fine - no crackle and clean signal. So I figure the problem is something to do with the channels fader?
Anyway, I can live without this channel. Is there an easy way of 'disabling' it via the circuit board leaving the rest of the channels intact? This would allow the rest of the board to work as it did before.
Currently, the only the board is usable is by panning channel 9/10 to the left and muting the main left channel. Everything else gets panned to the right and comes through fine. Unfortunately, that leaves me with a 1 channel mono mixer!
Any help or guidance well be gratefully received.
Cheers.
Cheers.
