bouldersoundguy
If you are using the studio live board you have the main plug up front that whoever is running the board uses. Then you have 4 auxes. Those 4 auxes are also on the left side of the board. hit the aux 1 button, then basically the fat channel becomes volume knobs. you turn up what channels you want that aux to hear. Do that until you have the levels set for each aux (1 -4 so they can have different mixes). Then make sure on the right side of the board you have the FX a and FX b clicked on the auxes and you should hear effects in the aux. Hope that helps
Then you connect those aux outputs to the headphone distribution amp and from there to the headphones. There is a headphone distribution amp, right?
