Z
		zocochico
Hi All,
I've been searching to see if any one else has this problem but haven't found anything yet. Basically I am running a couple of external pre-amps into the line in 1/2 on the back of the Firepod. What I have found is I cannot get those channels to clip anymore when I do this.
Here is an example: I am recording direct from my guitar into my Aphex 207 preamp, out of the preamp and into line 1 on the back of the Firepod. I can clip the preamp like crazy, turn the thing up all the way, but the Sonar just show the level in the red but never clips, as if there was a limiter on it or something. If you record this sound it is terribly distorted because you are clipping the preamp. This happens with 2 other preamps as well as other line ins.
I have tried taking the xlr outs as well as the 1/4 inch out to see if they would make a difference but it does not matter which out you use. If I plug straight into the Firepod and use it's inputs it clips with no problems. Can anyone suggest anything?
Thanks!
Thanks!
