FALKEN
nobody can answer this?
First you asked how WE would do it.nobody can answer this?
go figure. As to this last question, you have already answered it yourselfnah..I don't think it will be loose.
On the contrary? "YOU'RE" the one that asked how WE would do it! So when we tell you how because you say you don't know how, what do you do?Instead of answering my question, you are determined to have me do it YOUR way. what the hell.
I understand why you chose to use precut plywood, and its the same size as the fiberglass. But you asked about the airgap. I gave you a way of solving BOTH problems by simply adding a cleat to not only space the fiberglass out, but to give you a wider edge to fasten the frame to as well as the ply. So, do it your way. I don't really care how you do it. I ran into this same crap for years at where I worked as a CAD draftsman. I'd go to great lengths to show the shop how to build complex and very large projects. Some took very precise and elaborate jigs to install them, which I also would design for installation precision. But the guys in the mill would invariably do it their way, only to have the installers call me up asking how in the hell they were supposed to install this shit cause the jigs didn't match the drawings. I'd tell em..."how the hell do I know, ask the fucking shop guys. "
The point is....figure things out BEFORE you buy materials. I showed you a good way to do this, thats all I know. Remember, these are mobile, which means they are going to be moved around a lot. Hence strong joinery. At least to my way of thinking.
Sure would be easier and stronger. Just a suggestion though. Hell, if you set the frame on the floor, set the plywood inside of it, run a bead of adhesive around the joint and let it set overnight, it probably will be fine. Construction adhesive drys really hard over time and with the frames 90 degree joints being nailed it should work ok as long as the panel has a tight fit inside of it. For that matter, you could run a bead of yellow carpenters glue and it should work even better. Set the stuff on newspapers though. Yellow glue will run down into the joint, which is actually good. Good luck.Now wait a minute here. Can you explain to me just how you plan to make fiberglass "airtight".also try to make your gobo airtight. i will help its low absorption.
Besides, ever tried to blow in a bottle
Hell, you could lay a plain panel of 703 with no frame or nothing, up against the wall and they'll work fine. These are RESISTANCE absorbers, which will absorb to an extent just sitting in a room. Up against a boundary they'll work better. Give em an airgap and it lowers the bandwidth. It has NOTHING to do with being airtight. If that were the case, then all the people building these with NO FRAME would be wasting their time. But thats simply not the case. I think you have these confused with MEMBRANE absorbers. Besides, these are gobos, which by the way he is building them, are simply portable broadband absorbers. To really act as a gobo, you need panels with mass. 1/4" ply will resonate quite easily, which simply transmits the vibration to the air on the opposite face. Hence mass or stiffness, which is harder to vibrate. However, low frequencies simply diffract around them. Hence LARGE gobos.
lol.......RICK FITZPATRICK said:Good grief, I give up![]()
I live on the coast of Oregon, and with humidity changes and moving clouds(spraying outdoors) its enough to make your hair turn grey...er, mine already is
well, lets say fall out.......er....that too...damn....well lets just say its a pain in the ass. Hahahaha!!No prob. I just wanted people to understand whats going on, thats all. Sorry if my manner was less than cordial.sorry if i contributed to any confusion.
Wow, that is a great gobo design. I had never thought of making the back panel curved to add stability and so it would act as a diffuser. (That also seems to be going past a lot of the folks here.)RICK FITZPATRICK said:I would make them 5" deep 4' wide x 6' high. 3/4" Birch ply frames, with 3 layers 1/4" ply backs with 1/8" steel plate on the exterior, CURVED with 72" radius. Line with 4" 703 and fabric covered faces. Add casters and edge latches for fastening multiple units together.
Well, you asked.![]()
fitZ
