P
PhilihP
I just finished a song with all midi tracks and need it to fade-out at the end. I can’t seem to get it to fade to nothing. What do I need to do.
Phil
Phil
PhilihP said:I just finished a song with all midi tracks and need it to fade-out at the end. I can’t seem to get it to fade to nothing. What do I need to do.
Phil
As I indicated in my previous post, you should do this on the VMain. Doing it on the Main eliminates having to repeat the procedure for each and every track. Your steps are correct, just do it on the Main rather than on the individual tracks, it'll give you a smoother fade and allow you do it with just a single envelope.PhilihP said:It was confusing at first until I looked into making Envelopes. It worked fine the second time around, but for some reason I wasn’t able to save the changes the first time I tried it. If it helps anyone else, this is how it went:
In the Track View
Right-click on a track
Choose: Envelopes> Create> Volume
A Blue Line indicating the Volume Level will appear across that track
Right-click on this line where you want the Fade-Out to begin and
Choose Add Node
Right-click on this line where you want the Fade-Out to end and
Choose Add Node again
Pull down on the second node to lower the volume to nothing or near nothing
Do this on all the tracks
Thanks,
Phil
dachay2tnr said:As I indicated in my previous post, you should do this on the VMain. Doing it on the Main eliminates having to repeat the procedure for each and every track. Your steps are correct, just do it on the Main rather than on the individual tracks, it'll give you a smoother fade and allow you do it with just a single envelope.
Porter said:Also, remember you can right click on the envelope line in between the two nodes and select what sort of fade you want... slow curve, fast curve, jump etc.
Porter
Hey, it looks like I'm catching up.moskus said:DOH! Doubble post!
Moskus: 2 234 342
Dachay: 3
Right. And I also got the Virtual Main in the console view, I should have known because I've been there before. Well anyway, I still wasn't able to make it work. When I right-clicked I got other stuff on the screen, but nothing about envelopes. Maybe it only works with audio??? Well anyway I gotta run, be back later.moskus said:I think the V-Main is hidden by default. You see those Mix, FX, etc tabs at the bottom left of the Track View? A bit to the right of those tabs there's a button with an arrow (or something) pointing up. Click it and the VMain will reveale itself!![]()
