M
mrx
Scenario:
A song with two tracks of MIDI (bass and drums) that I saved as an SMF.
Converted the SMF to a 16 bit mono, 44.1KHz wav with Roland Virtual Sound Canvas.
Imported the WAV into a Fostex MR-8 for a guide track (setting the tempo map to match).
Recorded some guitars into the MR-8 (everything sounds fine).
Loaded up Cake with the above MIDI data (this time being played back through a Roland MBD-1 module).
Imported the guitar tracks (16 bit mono, 44.1 KHz wavs) from the MR-8 into Cake.
When playing back, the guitar tracks are in sync with each other, but ever so slightly "off" with the MIDI. Offsetting the MIDI tracks by a touch made things a little sound better.
Question - has anyone else experienced this when importing audio into Cakewalk, and if so, does the MIDI just need a slight nudge in order to lock everything up tight in sync?
Thanks for any thoughts or ideas!
