L
lufc71
Hi,
For a few years I've connected my Roland to my pc via a midi-to-soundcard connection with both Cubase and Cakewalk software. No problems, just plug it in and away you go.
As I travel a lot and the Roland is very heavy, I bought the Evolution to play through my laptop. Easy right? er..no!!
I've connected the midi out (it has no 'in') to the souncard, left the default channel as 1, then set the channel to 1 on the sotware, set a patch, set the input (the only option was the SBLive), set the output (again SBLive), but I get nothing. I now know that the Evolution works as I've hooked it up to the Roland and it works fine but I just can't get it to work as a midi controller straight to the pc. The instruction manual only mentions changing the output channel so I'm pretty sure my problem is with the software settings.
Are there any experts out there who wouldn't mind telling me where I'm going wrong. I'm sure it'll be something very easy but I just can't find it. As I always say "brain surgery is easy...when you know how to do it"!!
Many thanks,
Peter
I've connected the midi out (it has no 'in') to the souncard, left the default channel as 1, then set the channel to 1 on the sotware, set a patch, set the input (the only option was the SBLive), set the output (again SBLive), but I get nothing. I now know that the Evolution works as I've hooked it up to the Roland and it works fine but I just can't get it to work as a midi controller straight to the pc. The instruction manual only mentions changing the output channel so I'm pretty sure my problem is with the software settings. Are there any experts out there who wouldn't mind telling me where I'm going wrong. I'm sure it'll be something very easy but I just can't find it. As I always say "brain surgery is easy...when you know how to do it"!!
Many thanks,
Peter
Are you saying that any controller without onboard sounds would need an audio/midi interface other than the souncard?
