philbagg
Just Killing Time
Hello people
I've been doing a lot of mixing of my own bands stuff (using PT8 LE, Waves +
Sonalksis plug-ins) over the past few months. With all the various techniques
etc. for mixing, the one main thing I have a problem with is EQ.
I know the basics of what to cut/boost if something sounds a certain way,
but the problem I have is masking. I try to start with making the individual
instruments sounds more natural (if need be), and then start hi-pass filtering
anything that might have low-end content to leave room for bass, kick and
toms.
But the kind of problems I run up against are the beater of the kick isn't
audible in a mix, so I try to reduce around the 5kHz area in the offending
instruments but then they sound like they're missing it etc. Do you reckon I'm
using too much EQ where it's not needed, or not using it enough to get
satisfactory results?
I'm getting a lot better but I still don't feel satisfied by my mixes and it's not
compression or FX or anything, just EQ. I listen to commercial songs and
everything is perfectly audible and sounds effortless. I want that sound!
Any help?
Cheers,
Phil
toms.
Any help?
Cheers,
Phil
