Emotiva and Polk Audio??
  • Thread starter Thread starter d-rock
Home stereo speakers are designed to appeal to the consumer by sounding very rich in the highs and lows and less harsh in the mids. Some of the frequencies tend to be either exaggerated or softened by design. When it comes to making critical mixing decisions this can work against you because it leads to incorrect judgments.
If you plan to spend up to $1000 then you can certainly shop for proper studio reference monitors which will reproduce the source material more accurately. Many of them come with power amps built right in.
There only real difference between nearfield "studio monitors" and home audio speakers is the "studio monitor" label they stick on the loudspeaker. Other than that, you could be getting just about anything whether it's marketed as a "monitor" or a "speaker".
That whole thing about home audio speakers being intentionally "hyped" as compared to monitors is a popular myth, but it is a myth nonetheless. All one need to do to disprove it is to actually perform listening tests and check out the frequency response charts, and you'll find that both "monitors" and "home speakers" are all over the place when it comes to response characteristics.
In fact, I did a comparison of response specifications of a general sample of home speakers and studio nearfields last year, and the Polk LSi-9 was one of the speakers included in the comparison, and it landed pretty much solidly in the middle of the list. You can find the first of a multi-part article on this subject, including this comparison, by clicking here.
On paper, the LSi-9s greatest weakness is that it only goes down to 50Hz +/- 3dB on the low end (not much hype there, is there? ;) ), but if you're not mixing for THX soundtracks, hip hop or dance/trance, that may not be a killer.
What it all comes down to is you gotta find something that'll work with YOUR ears. Picking monitors for yourrself is as personal a decision and picking a bowling ball to fit your hands. Take some of your favorite CDs over to your friend's house and give them a listen. If they sound "right" to you, then you'll probably be able to learn to mix at least halfway decently on them. If they don;t sound "right" to you, your ability to properly translate mixes on them will probably come harder to you.
G.
There is so much more to speaker performance than just frequency response. True comparisons should include a variety of data such as dispersion, imaging, frequency analysis curve, tonal balance, dynamic range, detail resolution, phase control, transient response, distortion level, resonant frequency, off-axis response, speaker compression, crossover characteristics, and so on.
Here is an article that seems to support my suggestions about monitors vs. Hi-Fi speakers.
http://www.soundonsound.com/sos/jun02/articles/monitors.asp
http://www.soundonsound.com/sos/Jul02/articles/monitors2.asp
My conclusion would be this...
If you choose well designed "high end" Hi-Fi speakers, then yes, they are likely to be accurate enough for mixing. However, experience has shown me that many of the young members here who choose to use Hi-Fi speakers end up using low cost "junk" speakers left over from their teen years. I believe that many serious monitor designers choose better performing components, as a general rule, with more focus on accuracy. While designers of home theater systems and Hi-Fi systems are generally more driven by budget minded consumers. Cheap stuff sells faster.
My point was that if you tell everyone that they can use any speaker they want, some will end up using their laptop speakers. Is that the direction you want this forum to go?
i did notice its low end didn't hit that low and wondered if that would be an issue.
after reading the links and doing some research i guess they really aren't what i'm looking for. so comes the next question, any good ideas for good recording monitors under 600 for a pair???? (yeah i'm trying to save money for other gear i need to buy so i'd like to keep it under that)
I certainly don't want this forum to go in the direction of supporting false myths or in supporting things based upon how they're marketed instead of how they work.
As far as what Sound On Sound has to say, they sum it up fine right in their thesis at the outset:
SOS Article said:
"Can I use my hi-fi speakers as nearfield monitors?" It's a question often asked of Sound On Sound, but it's hard to answer, unless you're the kind of person that's satisfied with the reply 'it depends'...Even at the end of this two-part feature the answer is likely to be a shade of grey rather than black or white.
I sold loudspeakers - everything from home bookshelves to studio reference monitors - for many years, and worked with many manufacturers, and here is how loudspeakers (and practically everything else in this world) are typically designed: a manufacturer decides they need a product to fit a certain customer price range at a certain profit margin range, based upon what they perceive to be a market opportunity. Then they go out and either build their own components or - most often - find OEM components to outsource that will allow them to build such a product. They usually try to pick the best components they can for the budget, but often times decisions are made based upon supplier availability more than they are absolute quality of component. They then try to build the best system they can within the R&D budget they have and the time-to-market they have been given; both of which often place constraints upon the nature of the final product as well. Often times the identical components and design ideas are used in both monitors and home speakers for these very reasons.
Sometimes they wind up with a great product, sometimes they don't. Sometimes they'll make something that'll work for your ears, sometimes it won't. This is all equally true for home stereo speakers and studio monitors. Either way, their marketing department will tell you what you want to hear depending on whether they decide to market it as a home theater speaker or a studio monitor.
There is no more "hype" or flatness in one class of loudspeaker than there is an another. "Hype" takes money to engineer into a loudspeaker, you don't just "hype" a speaker and sell it for $100 and expect to make any money on it. Consumers like their stuff cheap. Cheap means not a lot of hype.
And it also take money to engineer "full and flat" into a studio monitor. You don't just make a full-range, flat "studio monitor" and sell it for $100 and expect to make any money on it. There's a whole lot of home recorders out there with cheap, crap "monitors" also.
You're right, there's a lot more to it than just the freq response specs; those were included just as a simple example roadmap. But the ultimate test is to listen. I can guarantee that given an equal number of "monitors" and "speakers" in a blind listening test, that you couldn't differentiate the two classes.
The most famous studio monitor in the world, the Yamaha NS-10, was not even a studio monitor. It was built by Yamaha as a home bookshelf speaker, and it was only when a few engineers started using them that Yamaha jumped on the bandwagon and "upgraded" it to the NS-10M ("M" standing for monitor.) And the NS-10 is just the opposite of hyped at the edges; it is, in fact, famous for it's midrange bump.
And don't even try to tell me that 90% of the "monitors" used out there are even close to flat. The vast majority used in home studios are nothing more than bookshelf speakers with a "studio monitor" plaque thrown on them, have an overall response as truncated and as uneven as those Polk Audios, and are harder for many ears to mix on than a decent pair of Altec Lansing computer speakers. Have you listened to most Polk Audio speakers? Calling those things "hyped" would be like calling Danny DeVito tall. And yet they are one of the most popular brands of home audio speakers out there.
Look, nobody's advocating mixing on crap speakers. But there's two problems; first there are are just as many crap speakers marketed as studio monitors as there are crap speakers marketed for home use, and second, one person's crap is another person's fertilizer - are you an NS-10 person or a Tannoy Reveal person? There's not many people out there that like both.
Everyone has to pick what works for them. If they can't or don't know how to pick by using their ears instead of their eyes, then it doesn't really matter what they pick; they don't have the ears for this stuff anyway.
G.
great. now i'm back to square one :confused::confused::confused::confused:
now i have no idea what to get now
...What it all comes down to is you gotta find something that'll work with YOUR ears. Picking monitors for yourrself is as personal a decision and picking a bowling ball to fit your hands. Take some of your favorite CDs over to your friend's house and give them a listen. If they sound "right" to you, then you'll probably be able to learn to mix at least halfway decently on them. If they don;t sound "right" to you, your ability to properly translate mixes on them will probably come harder to you...
To d-rock,
Glen made a good point here. You can learn to mix on anything once you get to know it. An example of this is; my own monitors sound bassy at the mix position so I already know I need to lighten up on the bass in my mixes. Just how much is an art I am learning as well.
The LSi9 speakers may work fine for you if you added a sub woofer to support the low end. Most of us who use small monitors end up doing that anyway. Or, (as part of my original point was,) with your budget you can afford to shop around through dozens of possibilities.
To Glen,
After looking through lots of speaker specs I agree that they are indeed all over the board. I just have trouble believing that no company out there attempts to make their monitors better than the rest. I always imagined there were at least a few design engineers somewhere who spend hours sifting through theil-small parameters and testing different box, baffle, and port designs to come up with the perfect match. You make it sound as though even those super dooper expensive monitors like Genelec, Klein and Hummel, Quested, PMC, and M & K are simply over-priced companies who got lucky in the professional marketplace. And all of the people who bought them are fools for paying too much.
Perhaps a more accurate description may be that modern day marketing trends have badly blurred the line between studio monitor and consumer speaker. Both sides have encroached far into the other's territory. Speaker companies like Egglestonworks and ATC are even selling products to famous mastering studios. My point is what we are seeing is a crossover effect. The line is badly blurred because each side of the fence steals ideas from the other side. It has been a quest to make studio monitors cheaper and to make consumer speakers sound better.
I understand your point is that the line has always been blurred. The same type of arguments can be made for race car vs. street car, athletic clothing vs. comfort wear, and doctor prescribed drugs vs. natural remedies. There are believers and nonbelievers attached to all of those topics.
I suppose we both at least agree that each type can be made to work in many different situations. I admit I have already used consumer speakers for monitors...and it worked.
To Glen,
Well, I didn't mean to sound *that* pessimistic, just realistic (no Radio Shack pun intended ;) ). Of course there are plenty of proud design engineers out there and most companies do try to create a product that they are indeed proud of.
But that always has to be balanced with the fact that they are *businesses* that have to make a profit in the real world, for if thy don't they'll never be able to both pay those fine engineers and give them an R&D budget with which they play with their designs. Just think about it for minute; consider the Genelec line. I'm just picking them at random (since you mentioned them), I'm not picking on them specifically, just using them as an example; I could just as easily picked JBL, Mackie, Tannoy, mAudio or any other company that make nearfield monitors.
Let's say (this is a story, not necessarily historical fact) that Genelec makes the model 8050 as their flagship monitor. A fine speaker, certainly something to be proud of, but somewhat pricey at over $2000 a pop. So the management says, "we need to sell to a broader market. Make something more affordable that we can put our name on." Push comes to shove, and they have an entire line of 80-series monitors that start with the 8020 for only about $500 each.
Now, just because the 8020 has the label "studio monitor" on it, does that mean it's going to sound anything like or be anywhere near the quality of the 8050? If the answer is yes, then that would just beg the question of why bother to pay two grand or more for the 8050. If the answer is no, then the question is what's so special about the 8020 that it gets the same "studio monitor" label that the 8050 gets? Their response curves are entirely different.
Then when you consider that there are companys that make/market "studio monitors" that are half or even 1/4 the price of the 8020s, and you gotta question the whole thing altogether.
Everybody's ears are different. It's this very reason why there are so many different makes and models of "studio monitor", with every one of them sounding different. If studio monitors were really all about flatness and accuracy above all else, over half of the makes and models out there would drop off the face of the earth. But the fact is that no two people can even agree of just what "flat an accurate" actually sounds like. I find my HR824s to be pretty flat sounding, but many others here with perfectly reasonable capabilities think they;re "hyped" sounding. Because we have different ears and preferences and interpret what we hear differently.
I knew a guy who made the best mixes using a combo of Advent 12" 2-way home speakers and Advent 6" 2-way bookshelves, driven by a standard Kenwood stereo amplifier. And on the other side of the coin, I have another friend who has a 5.1 THX home entertainment system equipped with 5 Mackie HR824s and the Mackie 1200(?) subwoofer, that'll just blow you away.
Yeah, there is a lot of overlap between the two markets, because there's a wide spread of quality from low to high in both markets, and because they both cater to the human ear and human monetary budgets. The engineers do the best they can (in most cases) on both sides of the aisle, but not everybody can afford - or even like the sound of - $2000/pop loudspeakers. Some folks can only afford - and actually prefer the sound of - Yamaha NS10s.
@ the OP: Read part 2 of my article for how to select what bowling ball of a loudspeaker suits you best. Hint: it's called "test listening" ;)
G.
you both make valiant points. i didn't mean for this post to become a debate on what is good and what isn't. but i've done a lot more research on what is what taking into account what was said.
i'll test the hell outta what i'm looking at now :) thanks guys
