brendandwyer
I'm having a bitch of a time isolating the cause of some nasty interference creeping into the audio chain in my setup.
When i boot up the Mackie SDR, i can hear the EMI representation of the hard drives spinning in the monitors. When i turn everything up there is definately EMI noise present in the mixer.
I have everything patched to bays. The Dsubs from the mackie are patched to the bays, then normalled to the 32-8's tape returns. When i unplug the Dsubs, the noise goes away. Obviously there is a problem in either the bays, or the dsub cables. If is present in all 3 (8 ch) dsubs. When i swap they are still there. I swapped bays, it is still there. I moved the mackie into another room, still there. I don't run inputs through the mixer so thankfully, none of this garbage has made it onto the indiv. tracks, but when i mix down, it's in the mix. which is not acceptable.
Any advice besides, unplug everything until you find it? Caus i've done that, and i've narrowed it to the connections between the mackie and the bay. Bu because i've swapped everything and no improvement, i'm still stuck.
Shanks
Shanks
