The other day I was playing my bass in the room of my house that I eventually would like to make into my "control room" (it is an upstairs bedroom). I was plugged into my SansAmp, which is powered by a wall wart power supply. The outlet it was plugged into is not grounded (my house is older) but does have a GFCI installed. At one point I had my right hand on the strings of the bass and reached up to turn on the ceiling fan with my left. When I did this I got a little zap...it didn't hurt but it did startle me. It wasn't enough to trip the GFCI either.
Would this be indicative of a ground fault in the electrical outlet I was plugged into, causing the circuit to ground through me to the ceiling fan when I touched it? Could this outlet be grounded to a cold water pipe, or would that mean the ground fault was being sent to the water pipe, making the pipe hot?
I'd like to get this rectified ASAP...thanks in advance.
