Farview
We tried it, it didn't sound better. I have a bunch of different cabinets and two tube poweramps (marshall and mesa) and a solid state power amp. Not to mention a few tube heads lying around. This was the sound we wanted and this is how we got it.Farview- Great job on the guitars there... best modelled sound that I've heard to date (that i knew was modelled) but I can't help but wonder if it would have sounded better miced through a cab...
It's just a voltage change, there is no magic. What it can't do is emulate your cabinet in your room with your mic in front of it. (because that isn't what they used to make the model)I own a Pod Pro and use it all the time... but you've got to admit that it's a digital algorythem designed to imitate the miked cabinet... It's almost impossible to recreate an analog signal path digitally... it comes close... but not quite there...
That's been happening. There are far more 1176 plugins sold than actual 1176's. Same with EQ's. It's the same with most of the high priced hardware boxes.For example... There'd be a very small market for outboard gear, if you could acurately digitally model the outboard gear in the box...
This will never be the case with mic preamps because you need a physical mic preamp to get the sound from your mic to your computer.
Where most of these modelers fall short is that they don't model any specific amp. For example, the JCM800 model isn't made from one JCM800. It's made from a bunch of them and then averaged into one model. One of the reasons for this is that no two JCM800s really sound the same, some were low endy, others were not.... So, when you bring up the patch and expect to get the same tone as the JCM 800 in your life, it doesn't happen and your disappointed.
That is probably something that they should stop doing- telling you what amp is being modelled. If they just used descriptive terms or stupid names, you wouldn't be expecting something specific. You could judge the tone on its own merits, not on some preconcieved notion of what that amp is supposed to sound like.
BTW, sample 4 was also a Pod on all the guitars and bass.
