TelePaul
J to the R O C
Hey guys, just curious as to the impact capacitor value has on tone. Anybody care to shed some light?
No, you have it backwards. A capacitor is a high-pass filter. That's why a simple 1st-order 2-way crossover will have a capacitor in series with a tweeter - to prevent the low frequencies from reaching it. (An inductor will be in series with the woofer, to filter out high frequencies from reaching the woofer.)There is no simple answer to this question because there are many ways you can introduce the capacitor into the circuit. In a nutshell though the capacitor acts as a low pass filter. The intent is to attenuate frequencies above a certain level. There are many people who pay big money for pickups, and in reality it's the other electronics in the guitar that is making their tone suffer. For example, cheap guitar cables with high capacitance are notorious for effecting tone in a negative way. Don't focus on one component. Evaluate the whole package together.
Mmmmmmmmm....when you put a cap parallel in line with your pickup output...you roll off some highs.
So....that's a low-pass...right?
A cap is definitely high-pass.Yeah...I think it's how it's wired and in what type of circuit.
In the typical guitar Volume/Tone scheme...it's a low pass filter, attenuating highs relative to cap value used.
But the real answer was guitars use a cheap treble-bleed circuit or a high-pass filter, and the highs are passed to ground. Nothing complicated.
A cap alone may have a specific property, but the link JHC provided sheds light on how a capacitor can be used to create either a low-pass or high pass filter...depending on the whole circuit.
Low-pass filters
High-pass filters
As I mentioned earlier in the post...I wired a mini toggle with a couple of different value caps, and they knock off the highs....so the net result is a low pass filter controlled by the values of the capacitors used.
what's happening is that as you turn down the tone pot, you're shunting highs to ground.
The cap doesn't let the lows go to ground because it blocks them so the only freqs that get grounded out are the highs.
. But the real answer was guitars use a cheap treble-bleed circuit or a high-pass filter, and the highs are passed to ground. Nothing complicated.
